Steering wheel removal 1969 F100
Hello everyone,
I must replace my steering wheel, replace some horn components and see why the shift 3OTT lever has so much play, seems as if it should have more of a pattern to follow, it's real loose, I know the rubber bushing is shot and I can see the pin has lots of play.
Will I need a puller to remove the steering wheel?
Is there a thread or post within a build thread regarding a 69 steering column?
Please advise
All the best
Dan
Please advise
All the best
Dan
Never mind. I found the information on the interwebz. http://vintage.mitchell1.com/PClubDa...V2D7311002.pdf
on
I see the blinker switch arm is broken an will need replacing also. if not then won't cancel to the off position. There is replace kit but have just short wires to splice together for like under $20 bucks.
There is replacement units that comes with all new wires like $50-60bucks. But can be easy or hard depends how one goes about doing it.
This tool pictured below it what is used to remove the wire terminals out of the double face connector under the dash next to the column near where the wire exit.
Orich
Orich
Orich
Orich
DaveFordF150
12-17-2014 05:38 PM
ifurlong
18
03-27-2008 10:20 AM
bci101tractors
08-15-2006 09:18 PM
