Steering wheel removal 1969 F100
Old 05-11-2016, 07:41 PM
ThemanfromAlabam's Avatar
ThemanfromAlabam
ThemanfromAlabam is offline
Question Steering wheel removal 1969 F100
Hello everyone,
I must replace my steering wheel, replace some horn components and see why the shift 3OTT lever has so much play, seems as if it should have more of a pattern to follow, it's real loose, I know the rubber bushing is shot and I can see the pin has lots of play.
Will I need a puller to remove the steering wheel?
Is there a thread or post within a build thread regarding a 69 steering column?
Please advise
All the best
Dan
Old 05-11-2016, 08:07 PM
ThemanfromAlabam
Never mind. I found the information on the interwebz. http://vintage.mitchell1.com/PClubDa...V2D7311002.pdf
Old 05-11-2016, 08:21 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
no puller needed
loosen the big center bolt , leave it partially threaded on .
with a bigger socket over loose nut ,hit socket with hammer lightly a couple times .
wheel will push forward then pop out to loose nut , remove nut and wheel done .
Old 05-11-2016, 08:31 PM
ThemanfromAlabam
Thumbs up
Originally Posted by MIKES 68 F100
no puller needed
Thank you so much Mike! ...will do
Old 05-14-2016, 08:42 PM
ThemanfromAlabam
I am sure it was just me, everything I touch seems to turn to **** these days...it took me hours to get the dam thing off.
Old 05-14-2016, 09:25 PM
orich's Avatar
orich
orich is offline
I see the blinker switch arm is broken an will need replacing also. if not then won't cancel to the off position. There is replace kit but have just short wires to splice together for like under $20 bucks.
There is replacement units that comes with all new wires like $50-60bucks. But can be easy or hard depends how one goes about doing it.
This tool pictured below it what is used to remove the wire terminals out of the double face connector under the dash next to the column near where the wire exit.
Orich
Old 05-14-2016, 09:58 PM
ThemanfromAlabam
Thumbs up
Orich
I've been searching but I can't seem to locate either one part for a 69 bumpside....if someone could post a link or part number I would really appreciate it....I'm bad enough with leaving stuff on, don't want to be blinker man on the hiway
Old 05-14-2016, 10:22 PM
orich's Avatar
orich
orich is offline
Ford Pickup Truck 69-72 same Turn Signal Switch - F100 Thru F350 - From, Serial #G30,001
Orich
Old 05-14-2016, 11:05 PM
ThemanfromAlabam
Thumbs up
Orich
Thank you Orich...found a few $29.
Old 05-15-2016, 12:03 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Before pulling the wires up thru the column, tape them together and include a sturdy draw string so you will be able to draw the new wires down the column.
Old 05-15-2016, 08:13 PM
MIKES 68 F100
I cut the plug off my old one , with about 3" of wire left that way you can plug the new harness wires into plug one at a time by color .
DaveFordF150
12-17-2014 05:38 PM
Witty73
04-16-2010 06:27 AM
ifurlong
18
03-27-2008 10:20 AM
bci101tractors
08-15-2006 09:18 PM
mds01
1978 - 1996 Big Bronco
02-07-2004 06:48 PM
Quick Reply: Steering wheel removal 1969 F100
