Sponsored by: Real Truck
strange transmission problem
Old May 3, 2016 | 02:39 PM
xtal_01's Avatar
xtal_01
So, in my 99 Bounder RV (F53 chassis), V10
I think it has a 4R100 transmission in it (I have not verified this).
I had the oil and filter changed about 10K ago.
Runs and shifts fine .... then I stop and idle with it in gear (say stopped in traffic for a few minutes).
Now the thing shifts super super hard! I actually get rubber in all gears.
So I pull over, shut it off. Restart the unit and everything is fine again.
It does this very consistently!
I went to the local transmission shop. They said with 110K in an RV it could be anything and I should think about letting them rebuild it.
Now that is something I would do ... not diagnose a problem and just rebuild it. I thought a "professional" would actually look for the problem first.
I don't want to rebuild the transmission if there is small item that will fix this.
Thanks ..... Mike
Old May 3, 2016 | 02:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You need to read the codes. The places that read codes free (and the shop you went to) can't read these codes. You need a good independent shop or a Ford dealer. Once you have the codes we'll know where to start.
Old May 3, 2016 | 03:03 PM
xtal_01's Avatar
xtal_01
Awesome ....
Will any "reasonably price" code reader ... say in the $200 range ... be able to read these codes?
I need to get a code reader anyway so it would be nice if I could buy one that would read these codes also.
Just FYI .... here are some pictures of my "project" RV. My wife is paralyzed and I have reworked it to make it accessible and so that I can do her care while on the road: https://mcsele.shutterfly.com/2299
Thanks .... Mike
Old May 4, 2016 | 03:58 AM
Yahiko's Avatar
Yahiko
The AE comes to mind as being able to read the Extended Ford codes.
Extended not really being the correct word but you get the idea.
https://www.autoenginuity.com/produc...mily-ei01.html
Other options are the BIG tool truck guy's scanner or anyone that
has access to a VCM or VCM2 and IDS.
But really a shop that knows what they are doing and not a parts thrower
that will 9 times out of 10 cost you more that it really should of.
Sean <BR>
6.0L Tech Folder
WatsonR
Jul 27, 2024 12:58 PM
tjmike
Feb 18, 2018 01:20 PM
devolic
Jul 5, 2010 02:50 PM
Killzone001
1997 - 2003 F150
Jun 13, 2009 11:12 AM
ChronGen
Jul 25, 2005 03:08 PM
