Sponsored by: Real Truck
2002 6.8L V10 engine replacement
Old May 3, 2016 | 10:40 PM
abqgolfer's Avatar
abqgolfer
New at this and can't find the answer, please kindly help.
I have a 2002 F250SD with 232000 miles. Going home motor died. Removed motor, pulled the head and found a broken valve spring on the passenger side. Valve fused into the head. Major damage was substantial crack in the block.
My question I can't seem to find the answer on is "why" can't I use a 99, 00 or 01 V10 6.8L as a swap? All I've been told by others, is won't work, but I never get a response on how come?
I appreciate any helpful information.
Thank you.
Old May 4, 2016 | 12:36 AM
oak123's Avatar
oak123
I am not sure about the Fords. However, if swapping an engine from different years, even the same year, make sure the wiring harness and components match up. Otherwise you may find that you can't start the engine. One of my dads stories he told us. He was finally able to get it to run after hooking up wiring/components that originally belonged to that engine...
Old May 4, 2016 | 05:08 AM
redford's Avatar
redford
FTE Leadership Emeritus
IIRC:
The 2000 and earlier V-10s had 2V non-PI heads, and were a bit down on power. 275 HP at 400 lb/ft. You probably don't want those, but it would work if it is all you could get.
2001-2004 have 2V PI heads (Power Improved). 310 HP at 425 lb/ft. Anything from that period should work, but you may need to use the accessory drive, intake and exhaust manifolds, and wiring harness from your old engine.
The 2005 Excursion is a bit of an oddity. 2V heads, but rumor has it there is no knock sensor. Avoid that one.
kythri
Modular V10 (6.8l)
Jun 10, 2017 10:55 AM
hank1072
Modular V10 (6.8l)
Feb 27, 2017 12:21 AM
king-david
Modular V10 (6.8l)
15
Aug 16, 2012 06:42 PM
MN_Viking
Modular V10 (6.8l)
Apr 13, 2008 11:51 AM
MattMerkl
Modular V10 (6.8l)
16
Dec 15, 2006 07:41 PM
