390 crank ID
Old Apr 26, 2016 | 10:22 PM
elkarcher1716's Avatar
elkarcher1716
390 crank ID
So I need some help identifying this crank that is in my truck. The builder told me it was a 390 but after tearing it down to the block and crank I'm not so sure. How/where is any part numbers on the crank that will help me identify it? The builder told me to look for a 2T or a 2U stamped in the crank. Not sure I can trust him cause the stroke is 3.50 and the bore is 4.05 so I'm pretty sure it's a 360 and he just tried to take my money. Any help would be greatly appreciated.
also if I do have a 390 crank will 360 rods work with the 390 crank?
thanks
Tim
Old Apr 26, 2016 | 10:31 PM
mikeo0o0o0's Avatar
mikeo0o0o0
2U or 2UA is 390, the "T" is a 360 crank.
The 360 rods are too long to use on a 390 crank.
Old Apr 26, 2016 | 10:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2T = 1965/67 352 & 1968/76 360 / 2U = 1966/72 390.
1968/76 F100/350 360/390: The bore is the same (4.05"), the stroke is different. 360: 3.50" / 390 = 3.78."
Old Apr 26, 2016 | 10:55 PM
elkarcher1716
Thanks guys. So I have a 390 crank cause I found the 2U stamp but the stroke is still only 3.50. How can that be? I'm confused
Old Apr 26, 2016 | 11:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Measure again, a 2U or 2UA crank is going to have 3.784" stroke.
How are you measuring the stroke?
Old Apr 26, 2016 | 11:19 PM
elkarcher1716
Well my micrometer batteries died so I turned the crank until the piston was all the way at the bottom of the stroke and them had to use a tape measure. It was 3 1/2" to the top of the hole. I did that on all the holes so I don't think I did it wrong but I might have. Going to get new batteries tomorrow and make sure but
Old Apr 27, 2016 | 12:04 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Are you measuring this directly in the bore with the head off or are you measuring through the spark plug hole?
Old Apr 27, 2016 | 01:18 AM
elkarcher1716
In the bore with the head off. The engine is out of the truck and on the engine stand.
Old Apr 27, 2016 | 02:34 AM
Tedster9's Avatar
Tedster9
Micrometer batteries...
What kind of BS is that? /jk Sounds like blinker fluid or left handed crescent wrench!
Old Apr 27, 2016 | 09:23 AM
flowney's Avatar
flowney
With the heads off, a straightedge and a tape measure should be sufficient. The only tricky part is getting the engine to TDC and BDC (stroke = TDC-BDC). The harmonic damper should have a mark for TDC for Cylinder #1 and BDC is 180º away from that. Stroke = BDC - TDC.
Old Apr 27, 2016 | 09:38 AM
4x4slik's Avatar
4x4slik
A regular tape measure is not accurate enough for this stuff. It is made for carpenters and has built in tolerances for saw blade kerf. A micrometer or ruler is what is needed. And not a school ruler but a machinists ruler.
Old Apr 27, 2016 | 06:37 PM
flowney's Avatar
flowney
The 390 has a stroke of 3.784 whereas the 360 has a stroke of 3.500, a difference of 0.284 which is just a tad larger than 0.25 or 1/4" Thus, even a crude school ruler can be used to discern the difference between a 360 and a 390. There is no in-between. It's either one or the other IF it is a FE engine.
Old Apr 27, 2016 | 08:47 PM
elkarcher1716
I guarantee its an FE engine. This ain't my first rodeo with FE ' s. Just don't understand the stroke measurement that I am coming up with. Either way the crank is a 390 so I know you can't intermix rods so it is what it is. I now realize I got screwed on the build and will have to start over. Thanks for yalls help.
62uni4x4
Jun 5, 2005 08:59 AM
biggut
Dec 23, 2004 10:03 AM
Seifferlein
Jul 18, 2003 06:59 PM
blue66f100
Jun 8, 2002 06:52 PM
earthworms
Mar 28, 2001 11:19 AM
