building a 427
Old Jul 17, 2003 | 04:58 PM
Seifferlein's Avatar
Seifferlein
building a 427
can a 390 or a 360 be changed into a 427? would there be machine work invoved? If so what kind (boring, clearancing, etc.)
thanks
brad
Old Jul 17, 2003 | 08:36 PM
FE427TP's Avatar
FE427TP
building a 427
No, the 427 was a special casting, you can put a 428 crankshaft in a 360 or 390 though for improved torque and horsepower
Old Jul 17, 2003 | 08:46 PM
Seifferlein
building a 427
thanks for the response. What cid would I be at with that crank? Also, what type of crank shaft is it that is used in a 360 block to make it a 390?
thanks for the help
brad
Old Jul 17, 2003 | 10:58 PM
67 428 Fairlane Ranchero's Avatar
building a 427
If you use a 428 crank with a 390 bore you have a 410 (mercury 66-67) but you have to either have a 390 piston shortened or use a early 70's 390 low compression truck piston. To make a 360 into a 390 you have to have 390 crank and rods and sometimes you can use your 360 piston, depends on pin height and your desired compression. either way you would probably have to change rods crank and pistons. I will have a good 428 crank for sale when I order my stroker kit I also have lots of 390 cranks and lots of rods. Good luck
Old Jul 18, 2003 | 02:40 PM
willowbilly3's Avatar
willowbilly3
building a 427
Scat has some stroker cranks and you could use one of those to get the cubes but they couldn't give me any details at all about the installation or where to find pistons, piston rod combos ect.
Old Jul 18, 2003 | 06:59 PM
building a 427
flatlander Racing has stroker kits.
