carburetor throttle linkage
Old Apr 24, 2016 | 08:27 AM
bluesalomon's Avatar
bluesalomon
I just installed a y block 239 in my wifes 1954 f100 pickup and I cant figure out how to connect the gas peddle linkage to the 2 barrel carb. It had a straight six in it before the swap and the carb linklage was on the Left side. The 239 is on the right. I have looked everywhere for photos and parts to connect the gas peddle linkage with little success. Does anyone know the part number, picture or have a diagram? I think the linkage must go on the left sid, but how do you connect it?
Old Apr 24, 2016 | 08:52 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The linkage that bolts to the firewall in the engine compartment is different on the V-8's. The easiest way would be to get a V-8 linkage.
Old Apr 24, 2016 | 09:08 AM
bluesalomon
Thats my problem. I cant seem to zero in to what part I need. When I go to someplace like ebay, they all look different. There is a part on the left side of the carb that moves the throttle, but I dont know haw to connect it to the existing gas peddle linkage
Old Apr 24, 2016 | 10:37 AM
oldmerc's Avatar
oldmerc
oldmerc
I saw a V8 throttle linkage in the parts section at the top of our category
Old Apr 24, 2016 | 12:44 PM
bluesalomon
Thanks but I ouldn't find the posting....
Old Apr 24, 2016 | 01:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Upper (upper) pic with Manual Transmission: 1954/55 C = F100; D = F250; Y = F350; T = F500; TH = F600.
Lower (lower) pic: 1954/55 F100/350 with Ford-O-Matic.
Old Apr 24, 2016 | 05:00 PM
bluesalomon
Thank you so much! This helps considerably!
Old Apr 25, 2016 | 01:44 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Bought mine from Mid Fifty Part number 1613
Old Apr 25, 2016 | 05:49 PM
bluesalomon
Thanks! I appreciate your help!
Old Apr 25, 2016 | 06:15 PM
bluesalomon
I need the outside linkage that connects to the carb
55fordf100Gramps
Apr 11, 2013 06:20 PM
Jag Red 54
Sep 14, 2012 12:45 PM
fiftysixfordf250
Mar 29, 2008 01:40 PM
bhabben
Jul 29, 2003 07:33 PM
caddyman
Mar 24, 2002 03:28 PM
