Trailer braking
Old May 1, 2016 | 11:43 AM
  #31
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Originally Posted by montauk1
Never checked mine, but I have read on another RV site, that to have even braking we should have at least #12 wire from the pinbox to each wheel, & if possible the same length of wire from the pinbox to each wheel.
John
Lots of things going on back there and voltage drops a big one, the wires that went through the axle on my Dexter axles was maybe 16ga at the most, I replaced it with 12ga strapped to the axle when the original one shorted out. Electric drum brakes have a lot of variables that we would never put up with on a vehicle, every wheel has its own magnet that engages its own drum surface. They also may not have the same air gap between the drum and magnet , it takes more voltage to overcome a larger air gap. Electric drums will not come on the same rate all the time like hydraulic will, when I removed my drums when I changed to disk the left front shoes were 90% gone and the rest had various amounts of wear with none the same, the left front is the first brake that gets power from the controller on our trailer.
Denny
Old May 1, 2016 | 03:05 PM
  #32
montauk1's Avatar
montauk1
Denny
I have electric drums on my 2010 Montana, & I noticed in the mirror while getting into a site on the wet grass last trip that the left front would lock up as soon as I touched the brake. I guess a complete rewire job with 12 gauge is on the "to do" list.
John
Old May 1, 2016 | 04:15 PM
  #33
rvpuller's Avatar
rvpuller
Our Hitchhiker had #10 all the way from the hitch to the axles.
Denny
Muddy1
Mar 4, 2025 01:54 PM
brandonc17
All Things Towing
May 29, 2018 07:34 AM
Culvert
All Things Towing
Apr 30, 2018 06:26 PM
MYTRUCKNOWRATTLES
6.7L Power Stroke Diesel
53
Nov 27, 2013 08:50 AM
JE917
Apr 10, 2010 04:43 AM
