glow plugs
Old Apr 15, 2016 | 02:00 PM
  #46
Jterr's Avatar
Jterr
Just got back from having all kinds of test run and found for sure 2 bad injectors..
That sucks when the guy I bought it from said ha just replaced them.I guess I'm the moron
Old Apr 15, 2016 | 03:11 PM
  #47
Walleye Hunter's Avatar
Walleye Hunter
Take him to see Judge Mullion. Judy's good too but Mullion's hot.
Old Apr 15, 2016 | 03:32 PM
  #48
HKusp's Avatar
HKusp
Sorry to hear, but which 2 were they, and how was it determined that they were bad?
Old Apr 15, 2016 | 03:59 PM
  #49
Jterr's Avatar
Jterr
2 & 8. He ran a Buzz test and a Compliment test???, plus glow plug and some other that was over my head
Old Apr 15, 2016 | 04:00 PM
  #50
Pikachu's Avatar
Pikachu
A cylinder contribution test is pretty much worthless with anything other than an original, black cam position sensor installed. Even then, I wouldn't change an injector based solely on that result.
Old Apr 15, 2016 | 04:13 PM
  #51
Jterr's Avatar
Jterr
What then?? I'm gonna do the oil change to 4w-40 1st and see how that goes. Really don't want to spend $ for injectors....
Old Apr 15, 2016 | 04:19 PM
  #52
cruz2322's Avatar
cruz2322
glow plugs
Can someone point me in the direction of replacing glow plugs in a 2003 7.3. Seem what I keep finding is for 1997 model...
Thanks
Cruz2322
Have you tried the dealer in most cases their more adept to helping you as to where and how to do it, I would ask the guys in the parts department, don't waist your time asking the mechanic. Because more then not he'll just shack his head as to I don't know! And also have you tried U-tub.
Old Apr 16, 2016 | 12:06 PM
  #53
Jterr's Avatar
Jterr
Question..If I drain the engine oil will that remove the oil from around glow plugs and injectors, if I decide to go under valve covers????
Old Apr 16, 2016 | 01:04 PM
  #54
Pikachu's Avatar
Pikachu
No, it will not. There's no need to worry about the oil around the glow plugs. There isn't enough there to cause any problem when it runs into the cylinders. The oil that runs into the cylinders when an injector is removed comes from the high pressure oil rail in the head, so draining the pan has no effect.
Old Apr 16, 2016 | 03:32 PM
  #55
Jterr's Avatar
Jterr
Might I ask how to drain that...
thanks
Old Apr 16, 2016 | 04:22 PM
  #56
Pikachu's Avatar
Pikachu
Most people, myself included, don't drain the oil rails. It's common to just pull injectors 7 & 8 first and let all the fuel and oil collect in those two cylinders. Then just evacuate it with a tube and syringe or Mityvac.
Old Apr 18, 2016 | 01:41 PM
  #57
HKusp's Avatar
HKusp
Or put the valve covers on and secure with only a bolt or 2 each and crank the engine over a few times
Old Apr 18, 2016 | 03:59 PM
  #58
Walleye Hunter
Now that's my kind of solution. Thanks for that idea.
Old Apr 18, 2016 | 07:45 PM
  #59
Jterr's Avatar
Jterr
Try putting in Rotella T6 synthetic 5W-40 or a brand that you like in that weight. If it starts easier it is a good indicator that the tolerances on the poppet valves in your injectors are very close to being too tight.
Did the oil change and replaced 4 pints oil in HPOP.. Started after heating 3 GP's 3 times but no power till warmed up..
Old Apr 19, 2016 | 05:03 PM
  #60
Jterr's Avatar
Jterr
OK I pulled the drivers side VC off and found 1 injector had been replaced( had black coil other have gold). Also the harness is straight thru to outside plug-is that good or bad????
Had to quit for now tomorrow will check 2 and 8 injectors see if bad or ??
Any thoughts......
