It is a weird shifter unless you're used to how motorcycle shifters work.
The shifter in our 15 Jeep Wrangler is a but strange as well and if you bump into it sideways like I did the othe day while Dar was driving, it thinks you want to bump shift manually and it knocks it down a few gears.. Good thing we were only doing about 50 when it happened!! I was turning around in my seat to get something out of the back seat when it happened.. I would have thought there would be some sort of interlock!
Had an appointment with Hannah this morning, then drove around to a few mobility dealers to get quotes. They ranged from $10,800-$14,900. This stuff isn't cheap! Hoping we get approval soon, Hannah's new chair shows up tomorrow.
No kidding Randy! The largest chunk of that is the lift, which is one of the more expensive models. We are looking for one that you don't have to lower for passengers to enter and exit, and Ricon makes one called the Slide-Away. It's a dual-post lift that folds together as it stows.
