My folding mirror on the drivers side folds out good but when bringing it back there is a clicking sound and it doesn't move, a slight pull on it and it comes back ok. 2011 F350 SD. Does any one have any suggestions. thanks.:
Yep. Might be the grear stripped out. In the 4 years I had my 2011, I had both mirrors replaced under warranty on year 3 and 4. If your trucks under warranty then you're all good (so long as there isn't the slightest hint of damage on the housing). The dealership is required by Ford to take 4-6 pictures of the mirror at various angles to inspect for damage before authorizing a warranty claim. If it's NOT in warranty, then you should google search Autonation Ford Parts and look up the replacement there. It's about $800 which is about $800 LESS than buying it from Ford. Order the part and do it yourself.
