IPR TROUBLES ?
Old Mar 25, 2016 | 09:51 PM
  #61
Shaneb75's Avatar
Shaneb75
Strokin Okie
Originally Posted by Tideman
Hey Shaneb, I know air test, air test, air test. ;-) I'm s-l-o-w but I get there. Will do Monday-Tuesday.
Brother, after all the work you did it's a crap shoot. I probably would have done the same thing. Now you have a spare IPR.
Old Mar 26, 2016 | 09:45 AM
  #62
BLADE35's Avatar
BLADE35
Originally Posted by Shaneb75
Hey Benny, what should the IPR be at 2500 rpm? You would think I would know that by now!
40% IPR @ 2500 RPM
Old Mar 26, 2016 | 09:50 AM
  #63
Shaneb75's Avatar
Shaneb75
Strokin Okie
Sorry Benny, I misread that you were actually stating that 40% was spec not confirming a leak at 40%.
Thanks for REPEATING yourself! lol
Old Mar 28, 2016 | 07:58 PM
  #64
Tideman's Avatar
Tideman
Dummy Plug
Could this cause a lot of air to bypass in a sit test and be the cause of my no hot start problems. O ring is still good.
Old Mar 28, 2016 | 09:07 PM
  #65
Shaneb75's Avatar
Shaneb75
Strokin Okie
I don't see where that would cause a leak personally...
Old Mar 28, 2016 | 09:11 PM
  #66
Tideman's Avatar
Tideman
Then it's going to be injectors, the air was coming from around this spot. So I guess injector #3
Old Mar 28, 2016 | 09:22 PM
  #67
Shaneb75's Avatar
Shaneb75
Strokin Okie
Can you shine a light in each injector and have a good look? BTW, you probably just healed up from doing all the that work... Now this. I feel for ya!
Old Mar 28, 2016 | 09:29 PM
  #68
Tideman's Avatar
Tideman
No I haven't taken off the oil rail. It's a lot of air passing tru at or around the dummy plug. Any suggestions
I got a little help this time ;-)
Old Mar 28, 2016 | 09:40 PM
  #69
Tideman's Avatar
Tideman
Uh oh I'm starting to sound like 98. I'm not listening. What am I looking for if I shine the light on the injectors. A slight mist?
Old Mar 28, 2016 | 09:45 PM
  #70
Shaneb75's Avatar
Shaneb75
Strokin Okie
At this point I would recommend pulling the oil rail and inspect the top injector orings. Also see if the nipple cups are sloppy....
Old Mar 28, 2016 | 09:55 PM
  #71
Tideman's Avatar
Tideman
Ok, had injectors replaced 55,000 mi ago by a reputable shop. ( engines they know, rear ends they dont) Will take oil rails off tomorrow and look at nipple cups. Will post pictures because really don't know what I'm looking for other than signs of wear.
Old Mar 28, 2016 | 10:02 PM
  #72
Shaneb75's Avatar
Shaneb75
Strokin Okie
That is exactly what you are looking for, the o-ring will be eroded away in an area...
Old Mar 28, 2016 | 10:11 PM
  #73
Archy's Avatar
Archy
I have a spare ipr I can ship you to test so you don't waist money I like to have a spare for towing
Old Mar 28, 2016 | 10:24 PM
  #74
Tideman's Avatar
Tideman
Thanks Archy, I bought one a couple days ago and now I have a spare to help somebody out. That wasn't my problem even thou I thought it was. Then I thought it was stand pipe or dummy plug. Nope ;-) I'm getting there.
Thanks Shaneb , will post pictures.
Old Mar 29, 2016 | 01:13 PM
  #75
Tideman's Avatar
Tideman
I'm going to start a new Thread on this since it changed from IPR (which I replaced and that wasn't the problem) to nipple cups and injector seals
Carolina Rig
Nov 1, 2018 08:49 PM
Kemicalburns
Jul 28, 2016 11:50 AM
jesuscowboy
Oct 4, 2015 08:48 PM
BryanStein
Aug 1, 2013 11:57 PM
51dueller
Flathead V8 & Flathead 6
Apr 11, 2004 07:37 PM
