Project Excursion Kenne Bell Install
Old Mar 13, 2016 | 04:46 PM
rock2610d's Avatar
rock2610d
Finally got around to pulling my Kenne Bell V10 kit out of storage.
I will snap some photos of install and update this thread as I progress.
I'm a slow worker so this will take a few weeks.
Here is first photo of my system.
Still need injectors, fuel pump, and Snipper tune...5 star said they couldn't help.
Old Mar 13, 2016 | 05:42 PM
IMASAP's Avatar
IMASAP
Can't wait to see more of this ! And they say there is no replacement for displacement........
Old Mar 13, 2016 | 06:02 PM
Bently_Coop's Avatar
Bently_Coop
Will be following along.
Old Mar 13, 2016 | 06:14 PM
mecdac's Avatar
mecdac
Au contraire, a turbo and blower
Old Mar 13, 2016 | 07:36 PM
WE3ZS's Avatar
WE3ZS
I'll be following along AND fighting the temptation to follow in your footsteps!
Good luck getting it all put together and properly tuned.
Old Mar 13, 2016 | 09:47 PM
DOOM173's Avatar
DOOM173
Thumbs up
FINALLY!!!!!
Old Mar 13, 2016 | 10:10 PM
aortizexcursion's Avatar
aortizexcursion
subscribing!
Old Mar 13, 2016 | 10:22 PM
Apocalypse's Avatar
Apocalypse
Subscribed two days ago!
Old Mar 14, 2016 | 04:04 AM
mr.noodi's Avatar
mr.noodi
Subscribed
Old Mar 14, 2016 | 10:34 AM
robert_l_ross's Avatar
robert_l_ross
subscribed!
Old Mar 14, 2016 | 11:52 AM
RobRoss's Avatar
RobRoss
I wish Jim Bell was still making these things! I've known Jim a long time and bought a lot of Buick parts from him. He's a sharp guy!
Old Mar 14, 2016 | 12:47 PM
Greenscobie86's Avatar
Greenscobie86
Nice! Should be an exciting thread.
Are you going to replace the pump itself or get a BAP?
Old Mar 14, 2016 | 01:07 PM
rock2610d's Avatar
rock2610d
If you look at photo you will see a boost a pump, but I'm not installing it. New pump and injectors will be installed.
Old Mar 14, 2016 | 01:20 PM
Greenscobie86
Cool, didn't get a good look at the pic. What size injectors does the kit call for?
Old Mar 14, 2016 | 01:35 PM
rock2610d's Avatar
rock2610d
Kit specs oem injectors with boost a pump.
I will be using 25 lb injectors. My elevation would probley allow oem 19s but I will upgrade.
On my 1995 Eagle Talon tsi, my oem injectors don't max out at 15 psi boost and 6500 rpm. I have even hit 21 psi briefly with only 65% duty cycle on those injectors. Elevation is a funny animal.
Most oem injectors would max out at 1/2 that down below 5000 feet. Since I am at 8000 ft it takes more to max them out.
For instance this KB kit is a 6 psi system. At my elevation the first 3 psi just brings me to sea level. Apples to apples this KB kit for me is a 3 psi equivalent system. Below 6000 rpm oem injectors would probably work. Not taking that chance though.
