obd1 codes found
Old Mar 7, 2016 | 06:33 PM
  #31
scrobbie's Avatar
scrobbie
Originally Posted by scrobbie
ok thanks guys im working on replacing it as we speak! Thanks gentlemen!! Have a great day and i did get the smog pump removed completely! At least thats a plus! finally
Ok guys i got the new booster in it seems to be doing alot better at least for now and I will be replacing the master cylinder soon. Real soon! Oh and i still have yet to clear the CM codes also just updating you guys on what's going on thanks to all of you for the help!!!!! Robert
Old Mar 8, 2016 | 08:30 AM
  #32
scrobbie's Avatar
scrobbie
Hey guys if i was to buy a new master cylinder without the reservoir, do you think it would be ok to use my fluid reservoir on my old one? Or should i just get the whole thing?
Old Mar 8, 2016 | 12:55 PM
  #33
Lead Head's Avatar
Lead Head
If your reservoir comes off in one piece, I don't see a problem.
Old Mar 8, 2016 | 01:11 PM
  #34
scrobbie's Avatar
scrobbie
Ok i mean it only saves a few bucks but i was just wandering about it i mean it does just basically just hold brake fluid lol! Thanks man for the help!!
Old Mar 8, 2016 | 03:25 PM
  #35
burnse's Avatar
burnse
You had said earlier that you don't have a vacuum tool. I bought one at Harbor Freight for about $20. I know that HF is not the best, but when you're broke, any vacuum tool is better than none at all! Normally, I try to stick with Craftsman or Snap-On, but sometimes the cost just ain't realistic...
Old Mar 8, 2016 | 03:32 PM
  #36
burnse's Avatar
burnse
I believe this is the one I got at $15.99 (even better)
Fuel Pump and Vacuum Tester
Old Mar 8, 2016 | 04:19 PM
  #37
scrobbie's Avatar
scrobbie
Thanks brother! I do have one of those! I was talking about a handi vac vacuum pump like rla2005 was speaking of! But i agree about being broke when it comes to buying stuff unfortunately most of my hand tools are cheap ones lol except i absolutely refuse to buy cheap, vise grips or channel lock pliers lol unless i dont care about destroying them! Yeah some stuff from HF is ok and other stuff is alright. Just kind of depends on what you buy i guess
Old Mar 8, 2016 | 04:52 PM
  #38
rla2005's Avatar
rla2005
I have this one from Harbor Freight: Brake Bleeder and Vacuum Pump Kit
Old Mar 8, 2016 | 05:07 PM
  #39
burnse's Avatar
burnse
I have a set of four Craftsman vise grips I purchased in the nineties. The vise grips they (Craftsman) have now don't come close to measuring up to the quality of these...
Old Mar 8, 2016 | 06:15 PM
  #40
scrobbie's Avatar
scrobbie
Exactly they dont make stuff the way they used too thats for sure lol!
Old Mar 8, 2016 | 06:28 PM
  #41
scrobbie's Avatar
scrobbie
Yeah thats the one i'd like to get also hey man where's my code reader lol! Just kidding man! Appreciate ur guys help!! Maybe someone can answer me this, it has nothing to do with this thread.... But i don't want to start another! But when I turn the ignition switch it is not engaging the starter every time, for some reason? I dont think it's the starter relay/solenoid or the actuator is not broken yet, because if I back the key off, and turn it is far as i can it will start at least as of now. Also if you turn the key to off position and turn it just a bit to far the radio comes on and you have to turn it foward then, back to off! There is a sweet spot for it. Any ideas on this? Thanks guys!!!!!
Old Mar 8, 2016 | 07:53 PM
  #42
burnse's Avatar
burnse
Sounds similar to a problem I have on occasion. I'll turn key on, everything is good, turn to start, nothing...no click, nothing. Tried to jump-start it, nothing.
There is a contact in the starter relay circuit that closes when the automatic is in 'Park' or 'Neutral'. By jiggling the gear shift or going to N, I was able to start it.
I hope this helps...
Old Mar 8, 2016 | 08:10 PM
  #43
scrobbie's Avatar
scrobbie
Ok thanks i will try that next time cheers
Old Mar 8, 2016 | 10:29 PM
  #44
scrobbie's Avatar
scrobbie
Also guys i wanted to ask how do i check the air charge temperature sensor?
Old Mar 8, 2016 | 10:38 PM
  #45
scrobbie's Avatar
scrobbie
also which pin on the harness do i use to check voltage? Thanks one and all
