body mount hardware advice?
Old Feb 27, 2016 | 05:51 PM
dthut's Avatar
dthut
just purched a new body mount bushing kit, and it doesn't come with hardware. if someone before has made them please post a picture or digram of what you did. thanks a lot
Old Feb 28, 2016 | 08:43 AM
650's Avatar
650
Here is what I made. They crush the mounts 1/8".
Old Mar 30, 2016 | 10:05 PM
dthut's Avatar
dthut
hey 650, whats the i.d. and o.d. of the pipe you used? and im confused what the doubled up top washer is for. thanks for the advice.
cheers
Old Mar 30, 2016 | 10:29 PM
650's Avatar
650
I`m not 100% sure at the moment but if I remember correctly the pipe is just 1/2" black iron pipe. It is 1/2" inside and about 11/16" outside.
I made the double washers because I could not find 7/16" as big as the rubber mounts. So I welded the 7/16" washers to the 7/8" washers since they are about the same size as the rubber mounts.
Hope that all makes sense.
Old Mar 31, 2016 | 05:46 AM
vtpkrat2's Avatar
vtpkrat2
Good job 650. Always nice to see someone thinking a bit! Yup, the bigger the washer ,the bigger the hole so if a person needs a big diameter washer you need to weld a smaller washer to it to kind of fill the bigger hole and get a proper bolt/size hole.
Old Mar 31, 2016 | 08:25 AM
gijazbo's Avatar
gijazbo
im not a big LMC guy, but there prices on mounting sleeves are the best I have found.
Old Mar 31, 2016 | 03:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Mar 31, 2016 | 06:16 PM
winginit's Avatar
winginit
doesn`t bronco graveyard sell all this stuff? I dont have a welder.
Old Mar 31, 2016 | 06:48 PM
1977FORDF150's Avatar
1977FORDF150
Yea I used LMC as well good quality stuff
Old Mar 31, 2016 | 09:06 PM
dthut's Avatar
dthut
650 , so the washer with the welded stem sits on top bushing in-between cab and bushing its self? and the doubled up washer is for the bottom bushing? and you didnt bother with the double sleeve? thanks again for the help, im going to the exact thing, just confused on how you orientated it. i figured the body sat directly on the top bushing.
Old Apr 1, 2016 | 12:16 AM
650's Avatar
650
Yeah I have it the way you described.
I didn't bother with the double sleeve because any other time I have changed these out the sleeves are corroded solid.
fordka
Aug 29, 2013 08:45 PM
AggieOutlaw
Jul 24, 2013 05:32 PM
Bears-72
Apr 19, 2013 08:22 AM
85_Blue
Aug 17, 2010 02:17 AM
Scoarch
Jul 8, 2005 08:55 PM
