FICM Program Error
Old Feb 27, 2016 | 04:23 PM
WatsonR's Avatar
WatsonR
Don't have any other suggestions.... have a buddy near by to try it on his truck?
... if not, you'll need to call them.
Old Feb 27, 2016 | 05:23 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
x2
It sounds like a bad cord.
Old Feb 28, 2016 | 06:53 AM
Yahiko's Avatar
Yahiko
Did you look at the PHP FORUM ?
Power Hungry Performance Forum
Sean <BR>
6.0L Tech Folder
Old Feb 28, 2016 | 09:13 AM
dr67's Avatar
dr67
I remember reading about a problem similar to this one. The fix was unplugging the ABS. After that the FICM was able to be programmed. I dont recall much other info. But its certainly worth a try. I believe the main connector on the ABS unit itself was unplugged.
Old Mar 2, 2016 | 05:19 PM
oxt127's Avatar
oxt127
Well i spoke to php tonight. Tried to trouble shoot over the phone but couldnt come up with much of anything. Tried moving cord around. Also, mentioned anything in line with the pcm could interfere such as an edge juice with atitude. I couldnt find any evidance of one of those being on the truck, pcm cables look factory. Could there be anything alse getting in the way? If all else fails php does have a dealer about 45 min away i could try to get to on Saturday if they are open.
Old Mar 2, 2016 | 11:34 PM
WatsonR's Avatar
WatsonR
your SCT talks to the PCM, that proves it's not the OBD port. No codes present for the FICM, I would say its talking to the PCM... PHP cord or programmer from my perspective.
Old Mar 13, 2016 | 12:25 PM
dr67's Avatar
dr67
Did you Find a fix?
Old Mar 13, 2016 | 12:26 PM
oxt127's Avatar
oxt127
I was down to my local PHP dealer here in the Hanover area this Saturday it's either a bad cord or bad programmer as his plugged in and works right away
PJ-Hunter
17
Apr 6, 2014 12:45 PM
98woody
Jul 24, 2013 04:49 AM
Teds
Aug 4, 2011 10:07 AM
jdadamsjr
May 11, 2009 04:43 PM
ngng
18
Mar 16, 2009 01:51 PM
