SCT TUNER
Old Aug 3, 2011 | 11:30 PM
Teds's Avatar
Teds
SCT TUNER
i need help on how to use the tuner....matt let me know that my tunes were qued...so do i just plug to laptop and upload files to tuner then plug into truck?
how do i get baack to factory settings? does something need to be done before step one for this...
i am lost dont know what to do...
Old Aug 3, 2011 | 11:43 PM
Teds's Avatar
Teds
also whats the diff between sf3 and x3...mine says nothing but sct??
Old Aug 4, 2011 | 12:05 AM
DieselBeast's Avatar
DieselBeast
Don't worry the tuner is easy to use. When you program your truck with the new tune the tuner will store the stock one. To put the stock tune back in you plug the tuner in, select program vehicle and select return to stock. To program the tuner you need to go to sctflash.com and download live load to your laptop. You use that to transfer the files onto the tuner. Name each tune as you go. Before you program your tuner you should plug the tuner into your truck and select "read strategy" and write that number down. That's basically you trucks stock tuning. You can use that to get more "customized" tunes.
I have the sct xcalibrator 2. tunes by Tadd at elite-diesel.
Old Aug 4, 2011 | 12:16 AM
Teds's Avatar
Teds
i did that first...and sent him the v code, he now has my custom tunes ready and they are ready to be put into my tuner....
Old Aug 4, 2011 | 01:10 AM
DieselBeast
Your tuner is newer so you may not have to download live load like I did. You should be able to hook up to your computer and transfer your files. Provided he emailed them to you and you saved them to your computer. You might have to do an update at sctflash.com through the tech support. You'll need to enter the serial number that's on the back of your device.
Old Aug 4, 2011 | 10:07 AM
olfordsnstone's Avatar
olfordsnstone
I had to do the update on SCT's site before loading the tunes onto the tuner. I had trouble doing the update, however. The computer I used didn't want to cooperate. I called SCT customer support and they walked me through a different process, using the start menu, to update the device. They also helped me load the tunes as I was worried about messing something up. I probably really didn't need the customer support after updating but they were helpful anyway and walked me through it while on the phone. Good customer support. I recommend you call them for help.
72_Mach1
Ford Truck Parts for Sale
Jan 13, 2017 03:31 PM
PJ-Hunter
17
Apr 6, 2014 12:45 PM
98woody
Jul 24, 2013 04:49 AM
Jordan123
6.4L Power Stroke Diesel
Jun 17, 2012 01:04 AM
Jayybird
Mar 7, 2010 08:25 AM
