BullyDog Tuner!!! WTF??!!
Old Apr 3, 2014 | 10:27 AM
PJ-Hunter's Avatar
PJ-Hunter
While trying to chase down some issues we tried to return my truck back to stock. Tried several times before we finally got the ECU back to stock. Unplugged the tuner and the ECU switched back to tow/performance mode. WTF would cause this???
Tuner was the BullyDog Triple Dog GT tuner for diesels.
Triple Dog GT tuner
I'm just wow! confused as heck now
Old Apr 3, 2014 | 12:05 PM
Tugly's Avatar
Tugly
I never looked into this. I thought the Bullydog was a tuner, not a programmer.
Old Apr 3, 2014 | 12:19 PM
PJ-Hunter's Avatar
PJ-Hunter
They call it a tuner. That's why I am so confused as to why my ECU is doing this. All the while the tuner being unplugged
Old Apr 3, 2014 | 01:37 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Contact the manufacturer...
Old Apr 3, 2014 | 02:02 PM
PJ-Hunter's Avatar
PJ-Hunter
I did. They issued a case number and the mechanic is looking into it
Old Apr 3, 2014 | 02:10 PM
tdpower's Avatar
tdpower
If the pcm had a tow tune on it that would explain it. Either that or the tuner is messed up.
Old Apr 3, 2014 | 03:14 PM
Tugly's Avatar
Tugly
A tuner can't do squat to a PCM, except bypass it. How did you determine there is a tow tune in the PCM? Shift points?
Old Apr 3, 2014 | 03:21 PM
PJ-Hunter's Avatar
PJ-Hunter
I guess the way it felt and smoked. He was on Bully Dog tech support for an hour and they finally got it to revert back to stock mode and now the truck runs good again. Something screwy went with the tuner and now it's on its way back to BD to get fixed and then I'm gonna sell it.
If I wanna go fast I'll get on my street bike.
Old Apr 3, 2014 | 04:45 PM
greg_8507's Avatar
greg_8507
I had a few problems like that with my superchips programmer. Over time i figured out if I hooked it up to the computer and updated it prior to hooking it up to the truck i wouldn't have that problem. Very inconvenient.
Old Apr 5, 2014 | 08:55 AM
PJ-Hunter's Avatar
PJ-Hunter
Is there a tuner/programmer out there that does what it should? Meaning adjusting timing for the tune you select to put in the truck?
When I was on the phone with BD yesterday they told me that the tuner I have does not adjust timing, basically with each setting you just get more fuel.
Old Apr 5, 2014 | 09:00 AM
greg_8507's Avatar
greg_8507
I believe they adjust timing with gas engines. It's a little more pricey, but if you want more out of your tuner a custom tuner such as DP-Tuner might be more what you're looking for. Especially if you have mods.
Old Apr 5, 2014 | 09:10 AM
Dan V's Avatar
Dan V
Buddy had a Edge unit, when he tried to flash the Tow tune (97 OBS) on it went haywire. I did a little searching and found that Edge would next him a "special" Edge unit to bring back his stock program. He tells me that Edge told him, "The electronics are getting up in years on these trucks. Things start to get dicey."
They recommended he find a reman'ed pcm and swap it in.
Old Apr 5, 2014 | 09:17 AM
CampSpringsJohn's Avatar
CampSpringsJohn
A word of caution to the OP!
Should you go with a different tuner like the ones many of us use, don't be hard on yourself for not making the switch earlier.
Seriously, you will like the improvement!
Old Apr 5, 2014 | 10:18 AM
PJ-Hunter's Avatar
PJ-Hunter
Camp springs John. Which tuner do you speak of?
Old Apr 5, 2014 | 11:00 AM
HKusp's Avatar
HKusp
It depends on what you want/need. The forum sponsor DP Tuner has been used by many( including myself for 6+years), PHP has the Hydra which many other tuning companys have access to and can do their own custom tunes. There is Gearhead, Swamps, Brian at BTS, etc. All of them have greqt tunes and most have very good customer support. Tell us more about what you want, ie: switch on the fly, between tow, high idle, daily driver, race tunes, etc. do you need or want monitoring of parameters, etc.?
