Offroad & 4x4
Ultimate 4X4
Old Aug 23, 2003 | 11:08 PM
  #76
proeliator's Avatar
proeliator
Ultimate 4X4
I'd say between the two of you its final. Great choices!
Old Aug 23, 2003 | 11:13 PM
  #77
fordmudrunner2020's Avatar
fordmudrunner2020
Ultimate 4X4
At least now we will have a functional lift that we can use for something. Hey Pro did you get your 73 painted?
Old Aug 24, 2003 | 10:37 AM
  #78
NorthernFord's Avatar
NorthernFord
Ultimate 4X4
Originally posted by proeliator
Say what!? How does that make it better for street use as opposed to trail use? That method gives you better ride true, but more importantly it gives you waaay better flex, i.e. articulation. Which is what you want for off road use. Heck, I'm not opposed to a four link & coilover setup, those are killer too, I'm just unclear on your point.
edit: Portal axles are great, but things can only be changed once and they were changed to Rockwells.
- I wasn't thinking rockwells, a set of axles off of a unimog are what I was thinking about,
who says a 18" lift has to be stiff?, go with as soft a spring rate as you can get away with, and not only will you increase flex, but also wheel travel.
shorter lifts mean limited articulation due to limited wheel travel
Old Aug 24, 2003 | 11:25 AM
  #79
Texan1983's Avatar
Texan1983
Ultimate 4X4
not really, with 4 links and coils, you can get lots of droop to the wheels. plus we are cutting the fenders way out to help.
Old Aug 24, 2003 | 04:58 PM
  #80
proeliator's Avatar
proeliator
Ultimate 4X4
Right, Portal axles, like I said. BUT the change was already made to Rockwells which I was trying to explain. As far as your argument goes about a soft 18" lift, you aren't really accurate. It doesn't matter how soft of springs you get the sheer amount of drop vs mount points (which is why they are referred to as "banana springs") preclude a ride near as good as either of the other methods we've discussed. Also, a shorter lift does not at all mean less articulation, they are entirely different variables.
Old Aug 24, 2003 | 06:35 PM
  #81
RRMike's Avatar
RRMike
Ultimate 4X4
Unless you get like some 10 inch long shackles to let those springs stretch out
Old Aug 24, 2003 | 06:38 PM
  #82
NorthernFord
Ultimate 4X4
OK then, I agree completely with coil-overs, but by going to a softer spring rate you allow yourself more wheel droop, thus improving articulation.
and I didn't reallize that rockwells were already agreed upon.
One mod we should also look at is welding on a diamond plate flat bed, that way we will get more options for tool/spare parts storage, and it also would stiffen up the frame.
Old Aug 25, 2003 | 04:36 AM
  #83
Pkupman82's Avatar
Pkupman82
Ultimate 4X4
I like the flatbed idea, how about a headache rack to mount a few KC daylighters on? Maybe also a bed mounted wrecker-style winch system?
Old Aug 25, 2003 | 09:58 PM
  #84
NorthernFord
Ultimate 4X4
instead of a wrecker winch, what about using a VERY LARGE hydraulic winch, and I defenitly agree with a headacke rack.
Old Aug 26, 2003 | 04:30 AM
  #85
Pkupman82's Avatar
Pkupman82
Ultimate 4X4
Hydralic winch sounds good, how about one of those on board ARC welders for emergency trail repairs? On board air compressor too?
Old Aug 26, 2003 | 05:30 PM
  #86
NorthernFord
Ultimate 4X4
sounds good to me
Old Aug 26, 2003 | 05:40 PM
  #87
No_BS's Avatar
No_BS
Ultimate 4X4
need $ figures
Old Aug 27, 2003 | 04:03 AM
  #88
Pkupman82's Avatar
Pkupman82
Ultimate 4X4
I can't seem to recall the cost of the welder or the air system, but I will look it up tonight!
Old Sep 2, 2003 | 02:22 PM
  #89
No_BS's Avatar
No_BS
Ultimate 4X4
this kinda died.....
Old Sep 3, 2003 | 04:42 AM
  #90
Pkupman82's Avatar
Pkupman82
Ultimate 4X4
Errr...How about exhaust stacks up the back side of the cab? 80 bones about?
