Offroad & 4x4
Ultimate 4X4
Old Aug 22, 2003 | 11:02 AM
  #61
Texan1983's Avatar
Texan1983
Ultimate 4X4
look at the 4 wheeler mags USD that thing is awesome. smaller lift with lots of fender trimming. much more funtional
Old Aug 22, 2003 | 12:57 PM
  #62
proeliator's Avatar
proeliator
Ultimate 4X4
Oh, I fully agree. 18" is too extreme for real use, and if its all springs they will be serious bananas and ride/flex awfull. What you need is about 12" of lift, done by using stock length springs and flipping the shackles and dropping the mount points, soft enough to articulate well. The rest can be made up by fender trimming. One of you guys just need to state it as your change.
Old Aug 22, 2003 | 03:37 PM
  #63
No_BS's Avatar
No_BS
Ultimate 4X4
we could do a funky coil-over setup with 4 links.......
Old Aug 22, 2003 | 03:41 PM
  #64
Texan1983's Avatar
Texan1983
Ultimate 4X4
thats not a bad idea that sure would make it ride better and function better off-road.
Old Aug 23, 2003 | 12:41 AM
  #65
Pkupman82's Avatar
Pkupman82
Ultimate 4X4
It would have ALOT more travel too.
Old Aug 23, 2003 | 01:45 AM
  #66
VX's Avatar
VX
Ultimate 4X4
http://www.killeraxles.com/html/portal_axles.html
Worth a look, the portals (hub gears) can be adapted to other applications, like a Rockwell. Also allows for more height with a lower center of gravity. Plenty beefy for 49"-56" tires, too.
That's my addition, portal axles. Probably cost around $2500-4000.
Old Aug 23, 2003 | 03:45 PM
  #67
NorthernFord's Avatar
NorthernFord
Ultimate 4X4
on the front alxe add portal style ends on the housing from a unimog, usefull for all circumstances and adds 5-6" of ground clearance under the pumpkin, 1000$-2000$
Old Aug 23, 2003 | 03:47 PM
  #68
NorthernFord
Ultimate 4X4
That's a good idea but would only make it better suited to street use, and this is after all the ultimate 4*4,
Old Aug 23, 2003 | 10:31 PM
  #69
proeliator's Avatar
proeliator
Ultimate 4X4
Say what!? How does that make it better for street use as opposed to trail use? That method gives you better ride true, but more importantly it gives you waaay better flex, i.e. articulation. Which is what you want for off road use. Heck, I'm not opposed to a four link & coilover setup, those are killer too, I'm just unclear on your point.
edit: Portal axles are great, but things can only be changed once and they were changed to Rockwells.
Old Aug 23, 2003 | 10:34 PM
  #70
Texan1983's Avatar
Texan1983
Ultimate 4X4
i was wondering that too. stiffer is not better, more articulation and control is better, also keeping the center of gravity down is best for off-road with out getting hung up of course.
couldn't portal axles be considered a add on/ another mod to the truck? portals can be added to rockwells right?
Old Aug 23, 2003 | 10:36 PM
  #71
proeliator's Avatar
proeliator
Ultimate 4X4
Exactly, Tex.
Old Aug 23, 2003 | 10:40 PM
  #72
fordmudrunner2020's Avatar
fordmudrunner2020
Ultimate 4X4
Is the lift going to be a 12" because if it is I'll change it since I've been saving my change. And what style four link or leaf springs.
Old Aug 23, 2003 | 10:46 PM
  #73
proeliator's Avatar
proeliator
Ultimate 4X4
I changed the engine, RMike changed the axles, I think despite allot of talk nobody has actually called a change on the suspension so go with what grabs ya. I'm going to sling my next build with Rockwells and a custom fourlink coilover set up....if thats a hint
Old Aug 23, 2003 | 10:48 PM
  #74
Texan1983's Avatar
Texan1983
Ultimate 4X4
custom 4-link with coil overs sound good?
Old Aug 23, 2003 | 10:51 PM
  #75
fordmudrunner2020
Ultimate 4X4
12" lift with custom 4-link with coil overs is my change to the truck unless Tex hasn't made a change yet.
