Spin on filter conversion for ft engine
Old Feb 22, 2016 | 08:01 PM
chrissmallwood's Avatar
chrissmallwood
Hi all. I have a 330hd and it has a cartridge type oil filter on it. It seems pretty hard to find a filter to fit so I'd like to convert it to a spin on type filter.. Is there a spin on filter mount from another engine that I can swap in possibly the one from another fe engine?
Old Feb 23, 2016 | 07:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Subscribed. I would think YES a regular FE oil filter extension would work, but let's hear from some people who have actually done it.
Old Feb 23, 2016 | 01:10 PM
Pinzer's Avatar
Pinzer
My '78 F600 with FT 361 uses a spin on filter. That's the way I bought it, so there must be an adapter/extension available.
Old Feb 23, 2016 | 03:11 PM
hiball3985's Avatar
hiball3985
"IF" the FE will work on the FT be sure to find an original part. The after market parts have a bad reputation, the after market ones for Y blocks have caused nothing but leaks and headaches for almost everyone who has tried them..
Old Feb 26, 2016 | 10:29 PM
Destroked 450's Avatar
Destroked 450
Ford FT 330,361,391 all use the same spin on filter adapter that's used on Ford cars with the filter turned down, if your using this engine in a pickup use the 352,360,390 pickup adapter that points the filter straight out to the left side.
Old Feb 27, 2016 | 07:06 PM
chrissmallwood
What filter would I use?
Old Feb 27, 2016 | 07:14 PM
62fordF250's Avatar
62fordF250
Both of the adapters I have are for a FL-1A filter. From what I recall, Ford used that filter for a long time.
Tedster9's Avatar
Tedster9
Most everything is setup for FL-1A
Old Feb 27, 2016 | 07:16 PM
chrissmallwood
Sweet. At least those are easy to find pretty much anywhere
Outlaw56
Sep 10, 2013 05:16 PM
captian diesel
Apr 12, 2007 10:07 AM
Green_64
Aug 2, 2004 04:00 PM
chissler
Apr 9, 2003 05:28 PM
Chas1234
Mar 3, 2003 11:38 PM
