2011 Delete Questions
Old Jan 25, 2016 | 12:47 PM
superrangerman2002's Avatar
superrangerman2002
Think I'm close to pulling the trigger. Is 1100 reasonable for a sctx4 ss delete pipe, no limits egr block off?
Sounds like rudys is a pretty safe choice...any reason to look elsewhere?
I'm only looking at mostly stock deleted tunes.
Old Jan 25, 2016 | 02:32 PM
UGA33's Avatar
UGA33
You can get Gearhead tunes from Mike at No Limit. Those are the best tunes you can get on an X4.
Old Feb 11, 2016 | 03:59 PM
bbaudoin's Avatar
bbaudoin
I already have a MM race tuner. Does the EGR need to be deleted or blocked? Or can I just replace the CAT/DPF with a straight pipe?
Old Feb 11, 2016 | 04:02 PM
Blapensee's Avatar
Blapensee
You can just disable it. Block off plates are when you want to at an egt probe or if you want extra room take it out completely. I've ran it disabled then with block off plates until I put a new turbo on it then I just took it out.
Old Feb 11, 2016 | 04:24 PM
GCLL's Avatar
GCLL
Will just disabling it allow any soot to get through and clog it up?
I was just about to order the stuff to do this until I just noticed I have another radiator failure which will require another $800 minimum to replace. Second radiator in 64,000 miles. Unreal.
Old Feb 12, 2016 | 11:04 AM
bbaudoin's Avatar
bbaudoin
The way I understand it, the tuner will keep the exhaust valve in the closed position. So, the EGR won't see any soot. But the coolant will still flow through the EGR.
Old Feb 12, 2016 | 11:06 AM
GCLL's Avatar
GCLL
Gotcha, thank you.
Old Apr 11, 2016 | 12:23 PM
Shooteris1's Avatar
Shooteris1
I'm having a tough time just finding a single tune for SCT x4. Don't need all 4 tunes just a single delete tune. Any ideas or does anyone know of a vendor to directly buy just one tune to delete? Thanks!
Old Apr 11, 2016 | 09:36 PM
UGA33's Avatar
UGA33
Why not all 4? I feel like it will be the same price regardless if you get 1 tune or 4.
Old Apr 12, 2016 | 02:29 PM
shadetreezj12's Avatar
shadetreezj12
I paid 900 for a minimaxx on Amazon. 176 for the pipes. H&S egt solution/egr block off plates 79(??). you will reuse one of your egt probes from the removed exhaust for the correct readings.
The whole conversion took about 90 minutes.
Leave the urea alone (Minimaxx ignores/turns it off). All removed connectors from the exhaust get bagged and ziptied out of the way for when you decide to convert back.
Old Apr 15, 2016 | 12:59 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
Does GearboxZ make a Simple programmer that only deletes regens & retains ALL stock settings like the one they had for the 6.4L ?
If so, is anybody running one ?
Old Apr 15, 2016 | 11:53 PM
Shooteris1's Avatar
Shooteris1
Deleted for only 500. Used SCT -80
Flo pro- 200
Custom tune-150
Egr plates- 40
Bottom block off plate bolts broke off I will have to drill and tap to fix... I would suggest to soak bolts over night it might help. If you need info on custom tune inbox me I I'll point you in right direction.
Old Apr 21, 2016 | 07:26 PM
  #28
superrangerman2002
I still haven't got a tuner yet. Mainly due they money tree being a bit short.
I still search for tuners however.
I saw a tuner from PIP and replacement exhaust on eBay just shy of $800.
Anyone have any experience with a PIP tuner?
I know that some people are running a sct x4 tuner with PIP tunes but I've never seen the PIP tuner before.
Old Apr 21, 2016 | 08:03 PM
  #29
UGA33's Avatar
UGA33
This is just an opinion. In MY opinion, there are better tuning options out there than PIP. On an SCT device, Gearhead or IDP would get my vote.
Old Apr 22, 2016 | 05:21 PM
  #30
Tofan's Avatar
Tofan
Just want to say something here. If you are disabling your EGR, you better had buy block off plates or you can say goodbye to the valve when returning it to stock. The block off plates are cheap and take no more then 1hr to install and are cheap insurance that your EGR valve stays good while you have deleted.....
fordzilla01
6.7L Power Stroke Diesel
18
Dec 31, 2018 05:19 AM
tradosaurus
Oct 29, 2018 11:31 AM
alawrence
Sep 29, 2017 02:16 PM
sawtooth
6.4L Power Stroke Diesel
Sep 21, 2012 10:11 PM
captain_trucks
Apr 30, 2009 02:25 PM
