Washington Chapter Washington Chapter
Join Chapter, Leader: Tim Young
2016 Annual B.S. Thread!
Old Feb 14, 2016 | 11:05 PM
  #106
Yahiko's Avatar
Yahiko
No you need to do a 180º on that. I just need warning
so I don't have a Dr apt and most of those tend to be
the first of the week.
Just give me an idea on the when an I can work it out.
Sean <BR>
6.0L Tech Folder
Old Feb 15, 2016 | 12:32 AM
  #107
Bently_Coop's Avatar
Bently_Coop
Will do, USCG is still ordering parts, more than a month out. Honestly I'm only available Thursday-Friday most weeks.
Old Feb 15, 2016 | 01:55 AM
  #108
GruesomeJeans's Avatar
GruesomeJeans
I haven't been doing diddly squat. A guy on here named Matt who lives real close by is going to tear apart the Carter I have for my sisters truck, once it's rebuilt, I'll throw it back on and retune the motor, hopefully it will be in good working condition. I'm also still working on getting gravel. Yesterday(Sunday) I had the perfect chance to get gravel with time to spread it, then I realized the Quarry I go to was closed...
Old Feb 15, 2016 | 03:15 AM
  #109
Yahiko's Avatar
Yahiko
Being closed does tend to make it a bit more work.
Nothing like a gate to slow you down.
Sean <BR>
6.0L Tech Folder
Old Feb 15, 2016 | 05:45 AM
  #110
GruesomeJeans
I'm ok with waiting that whole "procrastination" deal is taking effect. I'm also waiting on a small amount of money from my work, a bonus of sorts that we get at the end of the fiscal year. That paired with my tax return and mounting paychecks should allow me to get a jump on ordering parts. The first being a steering box.
Old Feb 17, 2016 | 11:06 PM
  #111
Bently_Coop
I'm thinking of grabbing a rain barrel tomorrow, 50 gallons with this weather should fill no problem.
Old Feb 18, 2016 | 01:56 AM
  #112
GruesomeJeans
Mathew did really well on the rebuild of my Carter. I got it mounted up today and tuned, the Jeep is running pretty good so far. Tomorrow if I have time I'd like to try firing it up again to see how it starts cold.
Old Feb 19, 2016 | 06:02 PM
  #113
Bently_Coop
Thread I got the idea from:
https://www.ford-trucks.com/forums/1...shop-****.html
I finally finished this project last night with my Husky LED and stand. If you don't have the tripod stand it isn't as necessary to go as far as I did. I wanted to still be able to use it so I drilled to wholes and used nylock nuts to hold in place. I also needed a stud or way to mount it to the stand as the original handle was to short. I ended up cutting the head off a screw 1/4x20 3" , cut a slot to insert it and used blue loctite to hold in place. The stud is now 1.5" inserted with about the same out for the base of the light.
Old Feb 19, 2016 | 09:15 PM
  #114
Bently_Coop
@Old Brown Truck Ever go to the shooting range in Skyway? Other wise known as Romans Casino.
Been a long time since I was actually up there.
Old Feb 19, 2016 | 11:27 PM
  #115
Old Brown Truck's Avatar
Old Brown Truck
Not since it was a Supermarket. I used to play in a band that would play at El Tapiteo though
Old Feb 20, 2016 | 12:46 AM
  #116
Bently_Coop
Supermarket, never seen that unless your talking about IGA which is the Library or Grocery Outlet near Ezell's. When I was living up there in 2005 ish it was Roman's and last I checked still is.
Old Feb 20, 2016 | 12:57 AM
  #117
Old Brown Truck
I moved into the neighborhood in 1990. For the 1st year or two, the Roman's casino was a supermarket. I think it was a Tradewell? When I moved here there were 3 Supermarkets nearby. I live closer to the former Skyway Market/AH Drug. Both are now history. The AH is a dentist and the Market is a Church. I also live a couple blocks from Dimmit Middle school. I've seen lots of businesses leave the neighborhood since I've lived here.
Old Feb 20, 2016 | 01:29 AM
  #118
Yahiko's Avatar
Yahiko
We has a Albertsons go Church near me.
Sean <BR>
6.0L Tech Folder
Old Feb 20, 2016 | 02:49 PM
  #119
klbrown's Avatar
klbrown
Sorry. The way you worded that made me laugh.
Old Feb 22, 2016 | 08:58 PM
  #120
Bently_Coop
Skyway is not exactly prime real estate. It is also a unincorporated section of King County.
