2016 BS Thread...
Old Nov 19, 2016 | 09:59 AM
  #4036
56panelford's Avatar
56panelford
It hasn't completely blossomed yet but will go check and see if it does...have a good day Chris..
Old Nov 19, 2016 | 10:39 AM
  #4037
Brown Falcon's Avatar
Brown Falcon
Good morning. Off to look at some trees for the back yard soon.
Old Nov 19, 2016 | 10:41 AM
  #4038
892504x4's Avatar
892504x4
Getting fruit trees or something decorative?
Old Nov 19, 2016 | 11:02 AM
  #4039
892504x4's Avatar
892504x4
Have a good/safe day folks.
Off to Forest Grove for couple of hours.
Old Nov 19, 2016 | 12:04 PM
  #4040
Brown Falcon
Mostly for shade on summer evenings, and blocking the view from the big two story house being built behind us.
We have one smallish maple already, but want to add an autumn blaze maple, a birtch, and a quaking aspen.
Old Nov 19, 2016 | 05:47 PM
  #4041
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Good afternoon Oregon and everyone everywhere else. Duck hunting was worse than spoiled buttermilk this morning and extremely wet.
Getting ready to head back into Lowe's. After talking with the Warden she had some "executive" ideas that I need to go price out. I'm afraid with the dimensions we have, we may be talking custom cabinets which is going to be way out of the budget, unless I'm over estimating by lot, and I don't think I am.
Good morning John and those to follow.
Jim I have an ecm scanner if you need to get the codes.
I've got a scanner, Scan Gauge II, that I think should work that Mazda Protégé as long as it has a standard OBDII computer port which it should since it is a 2000 year model. Depending on what it tells me, I'm thinking I just make arrangements on Monday to take it down to Corey's and have him handle it. I hate working on that thing. Seems like you darn near need to tear a wheel well liner out of it or pull the engine just to add a quart of oil.
Old Nov 19, 2016 | 09:05 PM
  #4042
Brown Falcon
Good evening. I got two trees planted today. One red sunset maple and one jacqumontii birch. They should provide some good shade and privacy once they grow up a bit. I got the tallest ones I could.
Old Nov 19, 2016 | 10:34 PM
  #4043
892504x4's Avatar
892504x4
Good evening.
Survived trip one to Forest Grove, trip two tomorrow.
Evan, Renee would have me planting fruit trees.
Jim, I have a scanner that connects via blue-tooth to my tablet can read and clear codes plus look at real time data.
Old Nov 19, 2016 | 10:40 PM
  #4044
Brown Falcon
I won't do fruit trees because of the mess and the drunk yellow jackets in the fall if you don't clean it up quickly. Luckily Jackie just wants shade and pretty leaves in the fall.
Old Nov 19, 2016 | 10:57 PM
  #4045
Seabiscuit-P3
Veteran: Navy
Good evening Oregon and everyone everywhere else.
Made it back from Lowe's. I was right, Warden was wrong. Now to figure out how to break it to her without winding up out in the kennel for the night.
My scanner will give real time and will clear codes as well as long as the vehicle is fully OBDII compliant. My pickup isn't fully OBD II compliant so it is not fully functional in that. But, I am still able use it in the pickup for digital read on RPM's, Voltage, ECT, EOT, Boost and a couple of other things. my 96 didn't have a transmission temp connection to the computer so I had to go with a tradition gauge and sending unit for that. Getting that wired, routed and installed was much easier than trying to program the Scanner for the pickup.
Old Nov 19, 2016 | 11:09 PM
  #4046
892504x4's Avatar
892504x4
Evan, Renee would have all the fruit put up nothing to cleanup in the fall.
Jim, can you record the data from the ECM to look over later.
Old Nov 19, 2016 | 11:50 PM
  #4047
Seabiscuit-P3
Veteran: Navy
It doesn't record but it does save any codes it finds until I clear them. Works on the Merc, haven't tried it on the Mazda, this function does not work on the pickup.
With the Mazda the past CEL has been related to the MAF. If that is what it is this time, I'm going to have to dig deeper into the problem. This has had happened in the past and as soon as the MAF Sensor was cleaned it the code cleared.
Old Nov 20, 2016 | 01:42 AM
  #4048
cowboylogic57's Avatar
cowboylogic57
We had a nice sunny day for our club meeting....everything went well for that. Last meeting of the year.
Always a little sad to put them away for the winter, isn't it John? I've got some put away, some lined up to work on. Will see what I get done. Much as i would hate to see a long winter, we could use a lot of moisture.
Old Nov 20, 2016 | 08:34 AM
  #4049
892504x4's Avatar
892504x4
Good morning Oregon FTE and visitors.
Jim, MAF sensors do get dirty and need cleaning. I had to clean the one in our van.
Wayne it's been dry for while over on the dry side.
Old Nov 20, 2016 | 10:37 AM
  #4050
Brown Falcon
Good morning Chris.
