Stupid question
Old Dec 30, 2015 | 05:39 AM
Marioj87's Avatar
Marioj87
Stupid question
I'm going to start changing my own oil. The manual says to use 7 quarts but when I use to take it to my mechanic they only use 6 quarts. Should I go by what the manual says or by what the say?
Old Dec 30, 2015 | 09:19 AM
flyguy108's Avatar
flyguy108
Go by the manual.
Old Dec 30, 2015 | 11:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Go by the dipstick. Put 6 quarts in, run it for a few seconds while checking for leaks, then shut it down. Wait a minute, then read the dipstick. You'll almost certainly be a quart low. Add the last quart.
Old Dec 30, 2015 | 09:14 PM
steve(ill)'s Avatar
steve(ill)
what vehicle and motor ?
Old Dec 31, 2015 | 05:15 PM
1saxman's Avatar
1saxman
On my V6 which is supposed to take 6 qts, it comes to right in-between the max and min lines on the stick. Use what the book says, change the filter, drive it around to fully warm up, park on level area and check oil to see where the 7 qts comes to on the stick in your truck. Then you'll know for sure. I totally reject the practice of going by the dipstick. The damn book says 7, you put in 7. Does anybody think some oil pans are bigger/smaller than others of a given year/model/engine? They are not. The owner's manual tells you what kind of oil and how much. Do that and you're good. I don't even check the dipstick on my truck after changing the oil - I know it comes to halfway between the marks with the stated 6 qts. I always double check I'm putting in a 5 qt jug and 1 qt more as I put it in.
Old Jan 1, 2016 | 11:37 AM
Montana_Rig's Avatar
Montana_Rig
Go by the manual. Your mechanic might be good, but it's unrealistic that he can accurately recall the capacity for every single vehicle that comes into his shop. 6 quarts is fairly common for a V8... my dad's Chevy and my old 5.8L V8 Dodge both took 6 quarts. He probably guessed, but your manual comes from the factory with all your truck's fluid specifications. No guesswork there.
Old Jan 1, 2016 | 04:22 PM
Feedguy's Avatar
Feedguy
7 quarts with new filter. 5.4 liter https://www.fcsdchemicalsandlubrican...f/oilchart.pdf
Old Jan 2, 2016 | 08:29 AM
wrvond's Avatar
wrvond
Not a stupid question at all.
Places that perform oil changes do not use individual bottles (remember oil cans?) like we buy at the auto parts store. They purchase their oil in bulk in 55 gallon drums and pump oil in the motor. The pump has a meter that tells how much oil has been dispensed. So he's not actually remembering how many bottles of oil he poured into your engine. Or maybe his meter is out of calibration. Or maybe you've been driving around a quart low.
At any rate changing it yourself is a good step towards ensuring it is done right.
Old Jan 4, 2016 | 06:03 PM
Pgh Rebel's Avatar
Pgh Rebel
Agreed. Besides that, you'll save yourself a lot of money in the long run. Be sure to follow the recommendations in your owner's manual for the type/weight of oil to use as well. Many people will suggest using synthetic. To me, that's a matter of opinion. If you change it every 3000 faithfully like I do then synthetic may or may not be worth the extra expense. I do use high mileage oil though since I'm into six figures now. What motor do you have, how many miles? Like 1 Saxman said, the 4.2 takes 6 quarts. I believe the 5.4 takes more than that. Not sure about the 4.6. If you suspect your truck to leak oil, then check it more frequently. Good luck!
Old Jan 4, 2016 | 06:14 PM
akcowboy's Avatar
akcowboy
The 5.4 takes 7 with a filter change as mentioned. The mechanic may be leaving the filter on, and the motor will only need 6
dustyroad
Jun 27, 2018 01:19 PM
kissfan79
Sep 12, 2016 03:35 PM
mnjettr
2009 - 2014 F150
Aug 2, 2010 07:52 PM
umdstang
2004 - 2008 F150
19
May 17, 2005 01:24 AM
ramtruckman
13
Mar 12, 2004 12:02 AM
