Block heater tips
Old Jan 4, 2016 | 08:34 PM
  #61
Colorado350's Avatar
Colorado350
It was /seems very well made, not pressed metal like some of the very cheaply made units. Time will tell, so far about a month it's worked very well.
Old Jan 6, 2016 | 11:58 AM
  #62
Shovelheadrob's Avatar
Shovelheadrob
Originally Posted by Walleye Hunter
The word is that they were all built with a power cord. I'm curious about what for voltage you folks run over on the other side of the pond and what your plug looks like.
Originally Posted by Shovelheadrob
If it's there it will have a standard US type plug for 120v. We use 240v here for domestic stuff but we also use 110v on construction sites so I have a couple of transformers kicking around. Here's the plug I will be using.
Finally got around to locating my wires & plug, behind the lower bumper trapped behind the oil cooler! It has probably never been used as we don't often get really bad winters here in the UK & when I bought the truck it had spent the last 5-6 years in Spain & they have Christmas dinner on the beach! As I expected it has a standard US plug so I'll be changing that to make life easier or I might just make a short patch lead if I can find a US female trailing socket.
Old Jan 6, 2016 | 12:10 PM
  #63
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Have faith brother, the 16 year old truck block heater on my truck still works and the plug looked a lot worse than that.
I had my truck plugged in yesterday in and when I went out to look under the hood I could feel the heat coming out when I raised the hood up. It was kind of nice to lean over a warm engine in the cold weather.
Old Jan 6, 2016 | 12:41 PM
  #64
Walleye Hunter's Avatar
Walleye Hunter
There's guys on here that would kill for that plug cover you still have attached to your cord!
Old Jan 6, 2016 | 02:19 PM
  #65
Tugly's Avatar
Tugly
I bought an aftermarket cover and installed it.
Old Jan 6, 2016 | 03:16 PM
  #66
William Mark Brown's Avatar
William Mark Brown
I have that cover on my old plug. It's still on the truck. Since it's so cold here I was going to wait till spring to remove the cord from the truck. I installed a bumper plug so I won't need it anymore.
Old Jan 6, 2016 | 03:59 PM
  #67
droldsmorland's Avatar
droldsmorland
Thanks for posting the Kim info. Therein lies the problem I have a 6.2 gas which does not have the insertion depth that the Diesels do. Im limited by the blocks outer/inner core water jacket depth. 6.2s heaters screw directly into the blocks jacket, unlike the cooler header that the diesels have. Im likely limited to a "will fit" thermosiphon style if I can find a good convection route. I don't want to get fancy with a forced circ system. Im surprised the after market doesn't make a higher wattage unit for the 6.2 cuz the one in there aint worth a .....!
I have used these in the past with great success on gas and diesel gen-sets.
http://www.hotstart.com/assets/Data-...S-E-12-121.pdf
Old Jan 6, 2016 | 04:24 PM
  #68
Shovelheadrob
If anyone wants it, just drop me a PM if you're coming to the UK & I'll post it to you. Shipping to the USA would be too much.
Old Jan 6, 2016 | 04:27 PM
  #69
Shovelheadrob
I only have to change it as we don't use the same plug in the UK, if I cleaned it, it would be like new!
Old Jan 6, 2016 | 04:46 PM
  #70
F250_'s Avatar
F250_
It won't be quite as effective as full insertion, but if you have enough room outside the block area where the heating element inserts, you might be able to improve things a bit by using a short nipple and coupling (or just a male-female coupling) to let the longer heating element still transmit most of it's higher wattage into the coolant.
Just a thought.
Old Jan 6, 2016 | 09:13 PM
  #71
bigreentruck's Avatar
bigreentruck
Was up at Sister's over Christmas. Northern Nevada. Great country.
Got down to low single digits.
Started thinking. Went to Bing for a search. YouTube rocks. Showed location of household male plug awaiting to mate with a 25 foot cord.
Plugged it in at sunset. Snowed lightly overnight. Snow on truck EXCEPT the hood.
Told the tale. Started light normal.
Day before started hard and chugged and coughed a couple times then to run and fast idle. Added oil 15-40 stored in truck in the cold and it poured like cool honey.
Love the block heater discovery.
Bohen
6.7L Power Stroke Diesel
Oct 27, 2016 04:57 PM
Guzzo
Oct 21, 2013 03:43 PM
ghunt
General Diesel Discussion
49
May 20, 2013 04:22 AM
1994F2507.3L
13
Sep 9, 2010 09:51 AM
CheaperJeeper
35
Nov 13, 2008 06:01 PM
