'52 engine removal
Old Dec 9, 2015 | 01:38 PM
GoldCo's Avatar
GoldCo
Question '52 engine removal
prep'ing to make plans to yank out the original 215.
this would be my first engine removal -- pretty straightforward? a friend suggested it might be easier to drop it from below vs. pulling from hoist above.
any pointers? i tried searching a bit, but mostly just got posts that mentioned engine removal, not how-to. (but i'll keep looking.)
thanks.
Old Dec 9, 2015 | 04:06 PM
harleymsn's Avatar
harleymsn
thanks.
Remove the doghouse and pull right out the top. Trying to drop it out the bottom would be a major PITA.
Old Dec 9, 2015 | 04:10 PM
GoldCo's Avatar
GoldCo
"doghouse"
is it easier to take motor/tranny together or does it really matter?
thanks.
Old Dec 9, 2015 | 05:58 PM
52 Merc's Avatar
52 Merc
I think Joe means the entire front sheet metal clip when he says 'doghouse.' It will come out about as easy by simply removing the hood and radiator and lifting it over the grille. Lifting the engine without the trans will be easier. Less length and weight to deal with.
Going down rather than up with the assembly will be difficult getting past the axle and such. I don't see how that would work at all.
Old Dec 9, 2015 | 06:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check your max hook height to make sure you can lift it high enough to clear the front end. With V8's, there is also potentially a problem with the crane's ram running into the grill or bumper to get close enough to reach. I made this diagram to figure out if my crane could do it. It would, but only if I hooked right on the block. Your Six is taller, too.
Your crane needs to be real solid with all that weight swinging around up that high!
Old Dec 9, 2015 | 06:37 PM
raytasch's Avatar
raytasch
Believe Nothing
And if your crane lifts almost high enough, let some air from the tires. Make certain the shop ceiling is high enough. No way the engine will come out the bottom easier than out the top.
Have fun.
Old Dec 10, 2015 | 05:51 AM
F1 Mike's Avatar
F1 Mike
Just did this. Remove the hood, then the front end sheet metal in one piece. It'll take you 30 minutes to spin out all the bolts then two people can lift it off. Pull the radiator and the rest is pretty simple. Back in the summer we pulled the 351W out of my sons ski boat and had it hanging 6 ft in the air on a big cherry picker. Not something for the faint of heart.
Old Dec 10, 2015 | 10:33 PM
51PanelMan's Avatar
51PanelMan
When I removed the 215 from my 52, I took the radiator and hood out. Unbolted the engine from the trans and pulled the engine out. You'll need to move the engine slightly forward inside the bay in order to pull it up and out.
You can also remove the front wheels and put the frame onto jack stands to lower the height in the front so you don't have to lift the engine high.
Old Feb 11, 2016 | 04:29 PM
GoldCo's Avatar
GoldCo
Smile
thanks for the replies...
hoping the truck shows up monday and then i'll be looking to pull the motor on tuesday!
Old Feb 12, 2016 | 07:16 AM
Doc's Avatar
Doc
Don't you mean this would be your second engine pull?
https://www.ford-trucks.com/forums/1...gine-pull.html
Tell us your fabrication plans for installing that 5.8 into your truck. Did you rebuild the engine as you planned?
Old Feb 12, 2016 | 08:55 PM
ryans88gt's Avatar
ryans88gt
thermite is going to be the easiest way to go..
RIKIL
35
Oct 25, 2012 07:09 PM
Wawnosh
Jun 28, 2011 01:38 PM
cutlass
Apr 24, 2011 03:12 AM
sinstr_shadow
Jun 3, 2009 06:35 PM
wakojoe
Jan 23, 2006 11:41 PM
