A few questions
Old Dec 4, 2015 | 11:33 PM
aeford66's Avatar
aeford66
A few questions
I have a new to me 2004 Explorer XLT 4.0 SOHC. It throws the code PO401. I know this indicates insufficient EGR flow. I have also read that if can be caused by a bad DPFE sensor. Looking for the sensor, it appears to be a part of the EGR valve assembly. Can it be replaced separately? I am guessing not.
Where should I begin to look to solve the slow filling fuel tank? I checked the filler hose and saw no kinks or anything obvious. It also throws a PO463 fuel level sensor high reading. Could this be related?
I also need to replace the rear wheel bearings. Any recommendations as to brand?
Thanks for any advice.
Old Dec 5, 2015 | 12:02 PM
steve(ill)'s Avatar
steve(ill)
as you fill the gas tank, the air inside gets compressed and must escape.. There should be a vent hose near the top of the fill neck for the air to get out.. it could be pinched or plugged.. you might get under the truck, remove that small hose and see if that helps.. or blow air thru it to see that it is open.
Wheel bearings by TIMKIN are probably the best. You can buy cheaper, but most will be china.. not saying they are bad, but the quality may not be the same. Rear bearings must be removed and reinstalled onto the hub/ knuckle with a 20 ton press. If you don't know the procedure, don't start process.
Old Dec 5, 2015 | 05:24 PM
aeford66's Avatar
aeford66
Thanks for the response!
I figured that the Timken would be best, I know that some other name brands have farmed out production to china. I know the procedure, and have access to what I need to do it.
I did blow the hose near the filler and it did flow air, but i think that routes to the evap canister. I need to check further....
Another question, are any of the aftermarket timing chain tensioner dampers (screw into the heads) any good? I am getting a little rattle on startup occasionally, and understand these should be replaced periodically.
Old Dec 8, 2015 | 12:25 AM
redfury's Avatar
redfury
Timken aren't as good as they used to be, but I'd rather use Timken or Moog suspension parts over anything made in China when it comes to bearings. I read too many reviews where wheel bearings from China lasted roughly the equivalent of 3 oil changes ( not synthetic! )
andydunks
Jun 24, 2012 02:45 PM
RedBoat
Sep 4, 2007 12:03 AM
Keato
Sep 18, 2004 09:01 PM
bvillegator
Jun 19, 2004 10:02 AM
blueexpend
May 5, 2004 10:28 AM
