Help!! Frying Sensors
Old Sep 18, 2004 | 07:24 PM
Keato's Avatar
Keato
I have a 1998 Ford Explorer Sport with a 4.0L V6. Recently the check engine light came on with a code reading saying that the upper hose of DPFE sensor was off or blocked. I checked and the sensor was melted in half and the hose was burnt to nice crisp. I have no idea what to do. I've got to replace the DPFE sensor but i just want to make sure that i don't melt this one too. Thanks in advance.
Old Sep 18, 2004 | 07:38 PM
Gary B's Avatar
Gary B
get ready for several bucks for the hose(don't use vacuum hose). has the hose been routed to close to the egr tube? that could of melted it.make sure it is not to close toanything hot.
Old Sep 18, 2004 | 08:44 PM
Opera House Works's Avatar
Opera House Works
Normally, there is no flow through the tubes, only a pressure potential so the heating is minimal. If the hose slipps off from some maintenance work or develops a crack, hot exhaust is directed right to the sensor. I wouldn't be concerned as long as you replace both of these high temperature hoses.
Old Sep 18, 2004 | 09:01 PM
ranger88a's Avatar
ranger88a
If the converter is partially plugged, it can melt the sensor.
