Sponsored by: Real Truck
V10 Failures
Old Nov 25, 2015 | 02:57 PM
  #31
f16qaguy's Avatar
f16qaguy
Very interesting situation. Subscribed.
Old Nov 27, 2015 | 01:17 PM
  #32
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Fleetguy48138
the upfitters guide programs them to around 1200 RPM with the parking brake and PTO or Aux switch engaged. Altec is an approved upfitter and this should be happening in their units. I know that all of mine, from a different upfitter are bumping up.
The Altec shown in the photo above, and the one that came to my house the other night, did not use the V10 while operating the boom. There was a separate smaller engine onboard. The V10 was shut off during the work. I mention this only for your consideration on your future fleet purchases. It sounds like you replace trucks every 3 or 4 years.
If 81% of your fleet (with the failure of your 39th truck) has had a complete engine failure, and the root cause is said to be due to PTO operation at high idle, then it might be worth looking into these new hybrid boom rigs when the time comes to replace your fleet again.
What oil viscosity do you use in your maintenance program?
Old Dec 10, 2015 | 01:46 PM
  #33
Fleetguy48138's Avatar
Fleetguy48138
When it rains, it pours. 4 more this week... All so far with top end failures.
Old Dec 10, 2015 | 01:48 PM
  #34
Diamnd1's Avatar
Diamnd1
That's insane.
Old Dec 10, 2015 | 01:49 PM
  #35
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
What oil viscosity do you use in your fleet's V10's?
Old Dec 10, 2015 | 03:00 PM
  #36
Fleetguy48138
Our service is done at dealerships and service providers nationwide... as for oil viscosity, I would have to pull records from the Ford dealerships and other service providers that service the fleet.
Old Dec 10, 2015 | 03:14 PM
  #37
Fleetguy48138
Name:  Sunset ford pics 006 (00000002).JPG
Name:  Sunset ford pics 007.JPG
Size:  1.68 MBHere is some pics of a claim that ford tried to deny back in August that was inspected by a Ford Motor company service engineer. Said that tie wraps were ingested into the engine.. I was livid, and got the decision reversed when I asked them how could they be in such good shape after being in a combustion chamber. look closely and you will see the lock strips, not sign of heat damage and the little "lock" lines are still clearly visible. Not to mention, how would it even travel through the air filter, intake tube, throttle body and through the manifold itself.
Old Dec 10, 2015 | 04:23 PM
  #38
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
That is funny.
Sounds like you need to change service providers.
39 + 4 = 43 trucks down. Out of 48, you've only got 5 trucks left.
Have any of the previous failures been restored and put back on the road?
What was their diagnosis? Zip ties as well?
Who paid for the repairs of the restored trucks?
What was the final diagnosis of the other engines in the failed trucks that have been repaired, as determined from the tear down and analysis of the replaced parts?
Old Dec 10, 2015 | 07:00 PM
  #39
KellyfromVA's Avatar
KellyfromVA
Something here doesn't add up. Me thinks we're being played.
Old Dec 10, 2015 | 07:27 PM
  #40
Louisville Joe's Avatar
Louisville Joe
Maybe, but over the years I have seen a lot of cam follower (rocker arm) failures on 3 valve Mods.. Usually the roller seizes up, chews the cam, and eventually spits out, breaks the hydraulic lifter and bends the valve stem. Sometimes the valve spring retainers become dislodged and the spring flies off too.
Old Dec 10, 2015 | 07:40 PM
  #41
CampSpringsJohn's Avatar
CampSpringsJohn
How did the zipties get stuck in the valves?
Old Dec 10, 2015 | 10:15 PM
  #42
Boss08v10's Avatar
Boss08v10
Exactly.........
Old Dec 11, 2015 | 06:41 AM
  #43
don123's Avatar
don123
Yeah It would seem so.
Old Dec 11, 2015 | 08:34 AM
  #44
Fleetguy48138
Sorry You feel that way....
<table width="1407" style="width: 1056pt; border-collapse: collapse;" border="0" cellspacing="0" cellpadding="0"> <tbody><tr height="42" style="height: 31.5pt;"> <td width="60" height="42" class="xl71" style="border: 0.5pt solid windowtext; width: 45pt; height: 31.5pt; background-color: transparent;">UNIT #</td> <td width="164" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 123pt; background-color: transparent;">VIN</td> <td width="95" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 71pt; background-color: transparent;">MILEAGE</td> <td width="129" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 97pt; background-color: transparent;">DATE</td> <td width="222" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 167pt; background-color: transparent;">BY</td> <td width="315" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 236pt; background-color: transparent;">NOTES</td> <td width="64" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 48pt; background-color: transparent;">Repeat Repair</td> <td width="113" class="xl79" style="border-width: 0.5pt 0.5pt 0px 0px; border-style: solid solid none none; border-color: windowtext windowtext black black; width: 85pt; background-color: transparent;">Date in</td> <td width="122" class="xl79" style="border-width: 0.5pt 0.5pt 0px 0px; border-style: solid solid none none; border-color: windowtext windowtext black black; width: 92pt; background-color: transparent;">Date completed</td> <td width="123" class="xl73" style="border-width: 0.5pt 0.5pt 0px 0px; border-style: solid solid none none; border-color: windowtext windowtext black black; width: 92pt; background-color: transparent;">Days</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4264</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GYXBEC71586</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">95088</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">4/29/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Woltz and Wind</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">$10,000 estimate.</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border: 0.5pt solid windowtext; background-color: transparent;">4/27/2015</td> <td class="xl70" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; background-color: transparent;">6/5/2015</td> <td class="xl68" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; background-color: transparent;">39</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4266</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY3BEC71588</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Replaced Engine</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">30</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4267</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY5BEC71589</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">79216</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">3/19/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Koetting </td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">$10,000 bill</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">3/17/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">4/3/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">17</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4276</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY0DEB88591</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Superior Ford, PA</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">30</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4277</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY2DEB88592</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8/1/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Woltz and wind Ford</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced engine</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">8/3/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8/13/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">10</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl74" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: yellow;">4277</td> <td class="xl75" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">1FDUF4GY2DEB88592</td> <td class="xl75" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;"></td> <td class="xl76" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">12/7/2015</td> <td class="xl74" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">Freedom Ford, Morgantown WV</td> <td class="xl74" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">Poss. Elect issue… waiting for tech</td> <td class="xl77" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: yellow;">x</td> <td class="xl76" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: yellow;">12/7/2015</td> <td class="xl76" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">12/11/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">4</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4279</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY6DEB88594</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">52567</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">6/8/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Bill Brown Ford </td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced Engine</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">6/8/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">6/16/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4278</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY4DEB88593</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">40984</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">11/3/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Woltz and Wind</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Replacing engine. </td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">11/3/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">12/4/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">31</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4280</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GYEB88595</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">19031</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">12/8/2014</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Woltz and Wind</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced cam and rocker</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">12/8/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">12/23/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">15</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4280</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GYEB88595</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">25508</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">5/7/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Woltz and Wind</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced head, cam, lifters</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;">x</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">5/7/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">5/27/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">20</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4281</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GYXDEB88596 </td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">26465</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8/29/2014</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Rineke Ford </td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced Motor - looking for paperwork</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">8/13/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8/29/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">16</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4283</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY3DEB88598</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">55289</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8/5/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Seymour Ford, Jackson Mi. </td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Replaced head and rockers… damaged parts 3x</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">7/29/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">9/22/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">55</td> </tr></tbody></table>
Old Dec 11, 2015 | 08:35 AM
  #45
Fleetguy48138
<table width="1407" style="width: 1056pt; border-collapse: collapse;" border="0" cellspacing="0" cellpadding="0"> <tbody><tr height="21" style="height: 15.75pt;"> <td width="60" height="21" align="right" class="xl71" style="border: 0.5pt solid windowtext; width: 45pt; height: 15.75pt; background-color: yellow;">4285</td> <td width="164" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 123pt; background-color: yellow;">1FDUF4GYEB88600 </td> <td width="95" class="xl72" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 71pt; background-color: yellow;">61483</td> <td width="129" class="xl73" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 97pt; background-color: yellow;">12/7/2015</td> <td width="222" class="xl71" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 167pt; background-color: yellow;">Simmons Ford, Vicksburg MI</td> <td width="315" class="xl71" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 236pt; background-color: yellow;">Engine Ticking and knocking</td> <td width="64" class="xl74" style="border-width: 0.5pt 0px; border-style: solid none; border-color: windowtext black; width: 48pt; background-color: yellow;"></td> <td width="113" class="xl73" style="border: 0.5pt solid windowtext; width: 85pt; background-color: yellow;">12/8/2015</td> <td width="122" class="xl73" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 92pt; background-color: yellow;">12/11/2015</td> <td width="123" class="xl68" style="border-width: 0.5pt 0.5pt 0.5pt 0px; border-style: solid solid solid none; border-color: windowtext windowtext windowtext black; width: 92pt; background-color: transparent;">3</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4286</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GYXDEB88601</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">40281</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">7/17/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replace cam and rockers</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">7/3/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8/4/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">32</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4287</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY1DEB88602</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">86231</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">10/12/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Borgman Ford, Wyoming MI</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Rocker and valve failure, quoting engine </td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">10/12/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">10/30/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">18</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4289</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY5DEB88604</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">30755</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">4/7/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced head and rockers</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">3/25/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">4/7/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">13</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4292</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY0 DEB88607</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">20565</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">12/30/2014</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Replaced Rocker before it failed.</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">12/23/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">12/26/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">3</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4292</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY0 DEB88607</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">32000</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">8/31/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced head, cam, lifters</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;">x</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">8/21/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">9/8/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">18</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl71" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: yellow;">4294</td> <td class="xl72" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">1FDUF4GY4DEB88609</td> <td class="xl72" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">48120</td> <td class="xl73" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">12/9/2015</td> <td class="xl71" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">Bill Walsh Ford, Ottawa, Il</td> <td class="xl71" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">Engine Ticking and knocking</td> <td class="xl74" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: yellow;"></td> <td class="xl73" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: yellow;">12/9/2015</td> <td class="xl73" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">12/11/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">2</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4295</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY0DEB88610</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">30571</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">3/30/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced head and rockers</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">3/17/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">3/27/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">10</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4295</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY0DEB88610</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">28774</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">2/13/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">replaced cam and rocker</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;">x</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">2/13/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">2/18/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">5</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4295</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GY0DEB88610</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">49545</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">10/2/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">ordered head and parts</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;">x</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">10/2/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">10/15/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">13</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl71" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: yellow;">4297</td> <td class="xl72" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">1FDUF4GY4DEB88612</td> <td class="xl72" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">69212</td> <td class="xl73" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">12/7/2015</td> <td class="xl71" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">Simmons Ford, Vicksburg MI</td> <td class="xl71" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">Engine Ticking and knocking</td> <td class="xl74" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: yellow;"></td> <td class="xl73" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: yellow;">12/7/2015</td> <td class="xl73" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: yellow;">12/11/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">4</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4299</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GYEB88614</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">32504</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">5/5/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Friendly Ford, Roselle Il</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Ordered head </td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">5/5/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">5/12/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">7</td> </tr> <tr height="21" style="height: 15.75pt;"> <td height="21" align="right" class="xl67" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; height: 15.75pt; background-color: transparent;">4300</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">1FDUF4GYXDEB88615</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">65257</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">11/13/2015</td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">LaFontaine Ford, Lansing </td> <td class="xl67" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">Cam and rockers we paid $2500.00</td> <td class="xl69" style="border-width: 0px 0px 0.5pt; border-style: none none solid; border-color: black black windowtext; background-color: transparent;"></td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt; border-style: none solid solid; border-color: black windowtext windowtext; background-color: transparent;">11/13/2015</td> <td class="xl70" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">12/8/2015</td> <td class="xl68" style="border-width: 0px 0.5pt 0.5pt 0px; border-style: none solid solid none; border-color: black windowtext windowtext black; background-color: transparent;">25</td> </tr></tbody></table>
