Sponsored by: Real Truck
V10 Failures
Old Sep 11, 2018 | 08:35 PM
  #166
Djosbun's Avatar
Djosbun
Normally I am not a fan of resurrected threads, but this new info is superb! Thanks for taking the time to put the rocker arms side-by-side so we can see the oiling hole.
Great find! Obviously you take the time to properly diagnose an issue. A rare TRUE mechanic!
— Dave
Old Sep 12, 2018 | 07:46 AM
  #167
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by htrucks
This week we had a 2013 year model V-10 in our shop with 107,000 miles. The owner complained of ticking sound. We removed the head cover and discovered two seized roller bearings and a scored cam shaft as described in previous replies. It appears this problem was caught before damage to the rest of the engine. We replaced lifters, rocker arms and cam shaft and concern seems to be resolved.
What is interesting is that it appears Ford redesigned the lubrication port on the rocker arm. The old rocker arms (left) had a larger hole that directed oil straight up. The redesigned rocker arm (right) has a smaller hole that directs oil toward the roller bearings. Our guess is that the old design did not allow oil to reach the roller bearings, hence the failures.
If you read this thread, you'll find that the most likely cause of the issue was lack of oiling during extending idling because of a bad seal at the timing chain tensioner. That truck might be coming back
Old Oct 17, 2020 | 06:30 AM
  #168
Steven Bowles's Avatar
Steven Bowles
here is mine
Originally Posted by Fleetguy48138
Is there by chance anyone out here that runs a fleet of 2013 SD V10s with serious engine failures?
I have a fleet of 2011 and 2013 F450 SDs with the 6.8 liter V10. Right now, I am experiencing a high failure rate in the 2013's staring with what seems to be rocker failure on the # 4 and 5 cylinder.
Just wondering if anyone else is seeing this out there.
Failures (36 of them) have occurred between 25k and 57k miles.
Thanks.
check engine light came on still kept rolling for about 15 mins, got caught at light heard engine running rough drove another 5 mins ticking bAd. Plugged scanner in cylinder 10 misfire. Popped valve cover off went down the line feeling some rockers slightly loose got to 10 and I just grabbed it RIGHT OUT. IT WAS JUST SITTING IN POSITION
Old Oct 17, 2020 | 08:20 AM
  #169
FordCamping's Avatar
FordCamping
Hi,
What year is yours truck and how many miles? From your pics, you are on the older roller rockers that came out. Not sure what date Ford changed to the new rollers or they changed the valve guide tensioners. If yours has the older roller rockers, you may also have the older problematic tensioners and oil pump.
Earlier this year (120K miles) I did a total timing chain drive and tensioner rebuild to the new style, replaced all roller rockers to the new style, upgraded the oil pump to the Melling for the V10, and added an oil pressure gage so I can see what the oil pressure is. My chain tensioner gaskets were blown on both sides. I found about this issue while researching and doing other work on the truck. Since my 2005 F350 was built in late 2004, all the 05 engine redesign engine issues did not yet show up. I changed out mine before bad things happened and I wanted a reliable truck for another 100K miles. I like the performance of the engine, just have to get rid of the early years bugs out of it.
Old Oct 17, 2020 | 04:30 PM
  #170
Steven Bowles
Originally Posted by FordCamping
Hi,
2015 F650 tow truck I think I have 218k miles
Old Oct 17, 2020 | 04:59 PM
  #171
FordCamping
Thanks,
But wow, a 2015 with the old roller rockers? That is not that old. Anyone know what year Ford changed to the new roller rocker? and or putting in the new timing chain tensioners?
Old Oct 17, 2020 | 06:56 PM
  #172
DesertSmoker's Avatar
DesertSmoker
I just finished doing a full valve train replacement on my 2010 with 117K miles. What I have learned is the oil pumps and timing chain adjusters play a big role into issues with the cam roller followers. 2 recommendations use the melling high volume pump and use the melling cast iron timing chain adjusters to ensure proper oil pressure all the time. My original oil pump was very weak at idle so that was the reason for the upgrades. All the lash adjuster were fine and only 3 cam roller follower were questionable. I replaced all of it to ensure all of it would good for another 100K miles. It may be overkill to replace all the valve train but I work my truck so I look at it like a maintenance item.
Old Oct 17, 2020 | 07:04 PM
  #173
DesertSmoker
Here is a link to the Ford recall for the V10 cam roller followers. Recall
Old Oct 17, 2020 | 08:21 PM
  #174
farmerfromkansas's Avatar
farmerfromkansas
I have an appointment with a shop to tune up my '05 F450 V-10. Also going to replace the timing chains. So I need to have them check the timing chain tensioners?
And looks like I need to switch to 5-30 motor oil.
Old Oct 18, 2020 | 07:50 AM
  #175
Tom's Avatar
Tom
Just out of curiosity, why are you replacing the timing chains? Those aren't normally a maintenance item.
Old Oct 18, 2020 | 09:01 AM
  #176
farmerfromkansas
My truck has 191540 miles. Want it to go 300,000. Friend has a 5.4 truck, his started making noise and the timing chain jumped a tooth and ruined the engine. And his had fewer miles, so that is the reason for the change.
Old Oct 18, 2020 | 12:37 PM
  #177
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Is the Ford part number to the updated cam follower on the right hand side of your photo above 3L3Z-6564-A ?
Is the Ford part number to the previous cam follower on the left hand side of your photo above F8AZ-6564-AA ?
Gage2502
Modular V10 (6.8l)
Apr 22, 2015 09:03 AM
1979FordTruckMan
Jan 17, 2011 07:04 AM
PFD350
Modular V10 (6.8l)
Dec 28, 2010 02:36 PM
