Down pipe clearence issues.
Old Nov 24, 2015 | 06:10 PM
crop harvester's Avatar
crop harvester
Sounds like its time to put some relief bends at problem spots.
Old Nov 24, 2015 | 06:14 PM
DanielT28's Avatar
DanielT28
Probably. So that means I have to take my whole exhaust system apart just to get the downpipe off?
Old Nov 24, 2015 | 06:19 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You don't have to take the whole system off. You will however, have to remove the tranny crossmember and put a jack stand or two under the tranny and xfer case.
Old Nov 24, 2015 | 06:24 PM
DanielT28's Avatar
DanielT28
That sounds like a big pain. But I see what you're saying. Start there. And then if it still does it I may have to remove system
Old Nov 24, 2015 | 06:33 PM
sudsmcduff's Avatar
sudsmcduff
My mbrp 4" to 5" hits the same place. I had a thick piece of rubber in between it for a while. But then I decided to dent it with a hammer. Hear vibration against it time to time but not that bad
Old Nov 24, 2015 | 06:44 PM
DanielT28's Avatar
DanielT28
Old Nov 24, 2015 | 06:46 PM
DanielT28's Avatar
DanielT28
I found out that I could rotate the d I found out that I could rotate the tailpipe by loosening the clamp on the downpipe. Because it looked to me as if I need to be rotated for clearance and it looks like it worked
Aune163rd
Apr 19, 2011 08:04 AM
idahodisco
Sep 1, 2010 07:03 PM
trencherman
Oct 4, 2008 12:29 PM
crazer42
24
Apr 6, 2008 12:53 PM
wannaburn
Mar 30, 2004 04:40 AM
