No VIN?
Old Nov 14, 2015 | 05:51 PM
ozblitz's Avatar
ozblitz
No VIN?
Hey guys, i'm looking at at 67 rolling frame, but when we cleaned off the grime below Alt. frame area, I could not see a number? I found the 2nd one under the seat area, but the numbers are bigger?
The numbers were also sort of wavy, not in a straight line. Is that normal?
Sorry I dont have pictures.
Old Nov 14, 2015 | 06:00 PM
HIO Silver's Avatar
HIO Silver
FYI.. my 73 4x4 doesn't have a VIN stamp by the alternator. The second frame rail stamp is too hard to see. I just go with the flow.....
Old Nov 14, 2015 | 07:48 PM
ozblitz's Avatar
ozblitz
I hear ya. I would just like to get my ducks in a row, just in case? Im getting a 68 w/ bill of sale only, so I'd like to document the frame as much as possible.
Old Nov 14, 2015 | 08:13 PM
Ford_Six's Avatar
Ford_Six
My 72 F100 4x4 had it clearly stamped just ahead of the spring tower on the right frame rail. My F250 does not have one in the same spot. It ma be a difference in what line the trucks were built on.
Old Nov 15, 2015 | 04:48 AM
jowilker's Avatar
jowilker
I have always heard that there are 2 stamps on the chassis frame rail. 2 on the passenger side, 1 just ahead of where the front axle crosses under and the other under the cab. Number Dummy has stated that he has seen one on the front cross member that I have not. Don't know if you are close enough to go look further.
John
Old Nov 15, 2015 | 01:17 PM
351Cleveland C4's Avatar
351Cleveland C4
I have a 68 frame and the only vin stamp that I've found is the one under the passenger side floorboard. None farther forward than that that I saw.
My 71 doesn't have one visible on the frame, I assume it's under the cab. my 72 parts truck is the same way. but then again, I've never really looked for one on the 72.
Old Nov 15, 2015 | 02:28 PM
crozzymoto's Avatar
crozzymoto
My 67 f250 4x4 has a stamp on top of the frame a little behind the front passenger cab mount.
Old Nov 15, 2015 | 06:43 PM
ozblitz's Avatar
ozblitz
Man this sounds pretty common? I did find the one under the seat cab frame area, but it looked really wavy and the numbers were a larger print. Is that typical?
Old Nov 15, 2015 | 08:12 PM
351Cleveland C4
I don't really know what you mean by big wavy numbers. If it's a factory stamp then???? If that's the only vin you found then what's the problem?
Now if you found two numbers, that didn't match, then there would be cause for concern.
Old Nov 15, 2015 | 08:42 PM
Ford_Six's Avatar
Ford_Six
I believe the frame vins were not machine stamped, but hand stamped. Mine had a similar waviness to the row.
Old Nov 15, 2015 | 11:23 PM
ozblitz's Avatar
ozblitz
Thanks Ford six, that explains a lot. I"ll be sure to photgraph it and file it away.
TRUBLU77
15
Sep 11, 2015 07:08 AM
petersandberg77
Nov 24, 2006 08:09 AM
Randyb12
Jan 23, 2006 11:26 PM
stretch351c
Oct 21, 2005 12:44 AM
thelaw74
Mar 22, 2003 11:54 AM
