F250 door handle rod lock clip
Old 10-29-2015, 02:04 PM
jed1894's Avatar
jed1894
jed1894 is offline
Trying to replace a right rear door handle on my 01 7.3. Attached is a photo of the new handle with the unlock rod. Also is attached is photos of the door without handle. I pointed to the part that moves the lack to unlock.
Looking for the clip part number or photo that is missing. Or any ideas on a rig. I thought a hose clamp would work maybe with a nut on the rod?
Old 10-29-2015, 02:05 PM
jed1894's Avatar
jed1894
jed1894 is offline
2nd photo
Door handle
Old 10-29-2015, 04:51 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Your best bet for that would probably be a body shop. A Ford dealership body shop would probably be easiest, but any body shop should be able to find it.
Old 10-29-2015, 05:35 PM
tonym17's Avatar
tonym17
tonym17 is offline
ford has them......21952 maybe
Old 11-05-2015, 02:49 PM
jed1894's Avatar
jed1894
jed1894 is offline
Problem fixed
I thought I would finish out this thread with the fix. I have attached the correct part number for a right rear crew cab door and photos the actual part that cost $8 from Ford.
After removing the inner door panel and the actual door latch, the drop rod goes down inside the door and the clip closes on the rod. The plastic clip goes into the metal oblong ring. You have to put the clip into the oblong ring and then turn it to lock in. Make sure you put the plastic in the ring before clipping it around the door handle down rod. The best way is to put the door latch on and then connect from the other side where the door panel is. It's self correcting.
The following 2 users liked this post by jed1894:
Old 11-05-2015, 02:50 PM
jed1894's Avatar
jed1894
jed1894 is offline
Photo of clip
Old 11-05-2015, 02:52 PM
jed1894's Avatar
jed1894
jed1894 is offline
Photo of clip closed
Old 06-25-2020, 06:47 PM
Icanopen's Avatar
Icanopen
Icanopen is offline
Thank You, Picked up one from a Dealership semi near me. $6.35, Returned the wrong one back to Amazon.
boostin
03-09-2015 05:40 PM
Aaron Mitcham
1997 - 2003 F150
09-10-2013 02:06 PM
flyboy2610
WTB - Parts & other
07-04-2013 09:23 PM
Ian123
1999 to 2016 Super Duty
11-30-2012 04:37 PM
stuartmcnair
11-13-2008 09:12 PM
Quick Reply: F250 door handle rod lock clip
