Up pipe leak
Old Jun 23, 2020 | 07:17 PM
One Sock's Avatar
One Sock
Up pipe leak
Not too long ago I replaced the old turbo up pipes with some new bellowed pipes. The truck seems happier with the new pipes (judging by the butt dyno) but there's one problem: on the driver side, where the pipe connects to the exhaust manifold, there is some soot that leaks out in one small spot right next to the bolt. I've tried disconnecting the pipe and reseating it, and then clean the soot off, but it just comes right back. Does the ex man need to be taken to the machine shop to have the ball-and-socket joint cleaned up? Is there some kind of gasket I could use, or Permatex Muffler and Tailpipe Sealer; would it handle the pressure?
Old Jun 24, 2020 | 03:51 PM
SteveH-CO's Avatar
SteveH-CO
I doubt any sealer would last. You might find a private exhaust shop or truck center that sees and fixes a lot of this kind of stuff and get their opinion.
Old Jun 24, 2020 | 05:53 PM
Greasemonkee's Avatar
Greasemonkee
I was inspecting mine a few weeks ago wondering about leakage, deemed them suitable for use after sanding the high spots down. I had the trans out of the truck though. If you go so far as to remove the manifold I would use dychem and see where the high/low spots are and carefully use a cartridge roll on a dremel until contact is made full perimeter with hand pressure.
Old Jun 25, 2020 | 11:52 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Start your truck and place your hand near the sooted area and feel for the exhaust. That will tell you what kind of leak it is. Check it with the manifolds both cold and hot. Due to the expansion rate of the cast manifolds it may very well seal itself when it gets hot and expands. I will bet when hot it is not even a big enough leak to worry about.
Old Jun 25, 2020 | 01:42 PM
One Sock's Avatar
One Sock
Do you mean Dykem layout fluid?
Old Jun 25, 2020 | 04:34 PM
Greasemonkee
Oops, yes, Dykem, probably the blue paste that doesn't dry.
Old Jun 25, 2020 | 06:31 PM
slowsure's Avatar
slowsure
Blue paste that doesn’t dry is sometimes called “Prussian Blue” in the tool making industry.
Old Jun 25, 2020 | 06:45 PM
z31freakify's Avatar
z31freakify
Permatex makes a good copper exhaust sealant. I've use it once in a pesky up pipe to exahust manifold in a 6.0 chevy and worked good. Not sure how much more pressure our engines make but worth a shot trying it out.
Old Jun 25, 2020 | 09:57 PM
Greasemonkee
And in the medical industry, probably not the paste in the tube, but the same salt with it's deep blue pigment. My blood test evaluation from several years ago suggested taking prussian blue to help pull the nasty radioactive heavy metal, thallium.
jseim44
Apr 18, 2012 09:28 PM
heygibb
Aerostar
Jun 29, 2010 12:43 AM
sawtooth
6.4L Power Stroke Diesel
Dec 29, 2009 07:46 PM
alstieg
38
Oct 30, 2007 02:14 PM
