Sponsored by: Auxito
Help! Front End alignment after rebuild- caster issue
Old Oct 24, 2015 | 07:22 PM
UFM82's Avatar
UFM82
Hello,
I just replaced everything in the front suspension on my 2001 S-Crew 4X2 except the pitman arm. Everything else is Moog premium stuff. I assembled everything just as I removed it (truck had 181,000 miles and ball joints were toast) and took it down to the alignment shop when it was done. Now the issue- even with the new caster/camber washers installed they can get no more than +2.7° of caster? The range is +5.2° to +7.2°, with +6.2° as the preferred setting. My truck is sitting at +2.7° and it's all over the road as it follows all the irregularities in the pavement. Surely there's a way to get the caster back? I'm ready to contact Moog and see what is up with this. I'd appreciate any input!
Old Oct 24, 2015 | 07:50 PM
steve(ill)'s Avatar
steve(ill)
should have a lot more adjustment than that........ I would check another alignment shop and get a second opinion.
Charlie Tee
1983 - 2012 Ranger & B-Series
Nov 12, 2016 09:04 AM
WaterdogF150
1997 - 2003 F150
Dec 2, 2009 07:03 AM
Fordpup
Bronco II
Oct 23, 2008 09:19 PM
ThePheonixx2
Oct 23, 2003 06:40 PM
88grandmarquis
May 7, 2003 08:24 PM
