Not getting spark
Old Oct 23, 2015 | 08:38 PM
ford_maniac-68's Avatar
ford_maniac-68
Exclamation Not getting spark
I have a 1968 Ford F250 360ci 4spd. I am having issues getting it to fire. I had some timing issues and I just replaced the solenoid and distributor. Im not getting any spark. When i try to crank the motor over it makes a winding sound like the starter is free spinning but its not. Crank cam and distributor are all engaging but again no spark. What could be causing this problem???
Old Oct 23, 2015 | 09:48 PM
Tedster9's Avatar
Tedster9
Still running points and condenser, install known good condenser. Newly manufactured condensers are not too good, specifically.
Check for 12 volts at coil, and healthy spark from coil wire to ground. If so, problem lies in distributor. Make sure ground wire is present between points and breaker plate, etc.
Old Oct 24, 2015 | 09:05 AM
orich's Avatar
orich
Try Hot wiring it, this will by pass the known faulty ign switch issues.
Add a like#10-22size from +Hot Battery term. to the +side of your coil.
Then turn key to start it, if it starts check both ing switch & an it's rear socket plug for any over heating or burnt wires. The known bad ign switches had round copper terminals.
The Ign. Switches with the Flat blade type terminals were the fix for these poorly designed Ign switches.
Orich
Old Oct 24, 2015 | 12:23 PM
ultraranger's Avatar
ultraranger
With a 360 FE, I'm guessing you have a points distributor (?).
If so, put a timing light on it, turned where you can see the end of the timing light, and crank the engine over. If the timing light flashes, you know you have spark. If it doesnt, then there's a problem with the condenser, points, ignition coil, ignition switch or the ignition wiring.
Old Oct 24, 2015 | 01:26 PM
CougarJohn's Avatar
CougarJohn
You said you replaced the solenoid.
Do you still have the old one? Put it back on and retry. The ignition is fed from the solenoid on cranking and you may have been bitten by Shanghai garbage, dead out of the box . Or, try what Orich said, run a hotwire.
Old Oct 24, 2015 | 02:53 PM
wrhinehart's Avatar
wrhinehart
You said, "....winding sound like the starter is free spinning ........"
Take off the distributor cap and verify that the distributor is actually turning while you crank it. We need to be SURE that the engine is actually turning over FIRST.
We'll help from there.
Old Oct 24, 2015 | 05:27 PM
JEFFFAFA's Avatar
JEFFFAFA
2X. Op mentioned "timing problems" My 1st thought was timing chain shot so cam and dizzy not spinning. If it is spinning maybe OP did change the timing chain and gears but might not have lined up the gear's timing marks correctly by accident.
Old Oct 24, 2015 | 06:59 PM
ford_maniac-68
I havent changed timing gears yet but thats gonna be my next thing to do. Im trying the simplest steps first just so i know that they are new. I bought brand new factory ordered dizzy and it came with new points and new condenser cap and rotor. Im getting spark now but it is not cranking the motor to start. Everything is moving when i turn the key its just not igniting the fuel.
Old Oct 24, 2015 | 07:24 PM
Tedster9's Avatar
Tedster9
New distributor is a good thing but many of the new condensers are not.
Is the spark fat and blue, or weak - yellow/red.
Old Oct 24, 2015 | 08:52 PM
wrhinehart's Avatar
wrhinehart
My guess is that the distributor might not be "Stabbed" correctly.
First take off the distributor cap. Leave the rotor on so you can see where it's pointing when the engine is at "Top Dead Center".
Pull the coil wire and the #1 spark plug.
Hook up a remote starter switch on the solenoid or get help who will turn over the motor for you while using the key.
Put your finger into the #1 hole where you took out the plug.
Bump over the engine until the compression pushes your finger out and stop.
Look where the rotor is pointing too.
Observe where the #1 spark plug wire is on the cap. They should be in alignment.
If not. you installed the distributor incorrectly.
Let me know what you found and we'll go further.
We'll get it.
Bill
Old Oct 26, 2015 | 03:45 AM
whiskey runner's Avatar
whiskey runner
you said you had spark that's good.. did you check for fuel?.. or do as suggested and check timing..
Old Oct 26, 2015 | 05:32 AM
ford_maniac-68
Aftet i started gettin spark the carb wasnt pulling in fuel then i pumped the throttle about 6 times an its started pulling in the fuel but still a no go on firing. Imma be replacing the spark plugs becuz 4 out of the 8 are fouled up pretty bad.
Old Oct 26, 2015 | 08:22 AM
orich's Avatar
orich
Hmm fouled from what oil or gas? It weak spark can cause fouling also bad coil to bad spark plug wires to any enteral dizzy parts bad.
A heads up/ Your fuel pump pulls fuel then pushes the gas up to the carb from the pump just to keep your thinking straight. it should really only take 2-3 pump on the gas pedal once the carb has a good full fuel bowl and to set the choke closed.
What was the out come from my earlier post of trying to HOT WIRE to see if it we start that way. Or did you even bother to try it? In my Post #3
Orich
Old Oct 26, 2015 | 08:55 AM
whiskey runner
hum fouled plugs.. like orich said there could be many reasons for that.. did you just put in new ones??.. maybe your flooded... pull all the plugs blow some air in each hole and see what comes out.. if clean and dry, install a good set of plugs ..pump the fuel once looking in the carb throat to be sure accelerator pump is working then see if it will start
Delp73
Nov 5, 2016 07:43 AM
Mentadentt
Feb 21, 2012 06:25 PM
BJ_EPPERSON4201
15
May 26, 2010 08:21 AM
wyazel1
May 2, 2007 06:42 PM
airharley
Aug 6, 2002 03:49 PM
