Cold No Start
Old Oct 23, 2015 | 07:14 PM
jmaskew's Avatar
jmaskew
Originally Posted by bismic
At some point Jonathon, please load test the batteries individually!
Were you asking for IPR % Duty Cycle above? If so,
Injector Pressure Regulator
Short Name: IPR
PID: 221434
Units: %
Max/Min: 100.0/0.0
Equation: A*0.39063
Edit ......................................
Also (a premature guess) - if your batteries are OK and you are getting the proper rpm when cranking, then I am leaning towards a cam or crank sensor (due to the 0 inj. pulse width). Posting the requested info above should point us in the right direction.
FUEL PW (fuel pulse width) - Pulse width defaults to 0 w/o CKP signal, RPM below minimum spec, or low ICP, or bad CMP signal.
I was just searching online for the Cam/Crank Sync Pid... what I have found is that its the same as the FICM Sync Pid which doesn't seem right.. I'm going to let the batteries charge up to 100 % tonight.. the batteries are just over a year old... here in Vegas I haven't had a set of batteries last more than 1 1/2 years. Ever since the last FICM failure I have upgraded the Alternator to a 200amp plus I am extremely **** on volts and watch the batteries like a hawk.. Thanks again Mark for your help!
Old Oct 23, 2015 | 07:18 PM
bismic's Avatar
bismic
I posted the Cam/Crank entry (custom PID) - it differs slightly from the FICM sync (equation is different - A:1 vs A:0). I am not sure I understand your question.
Old Oct 23, 2015 | 07:33 PM
jmaskew's Avatar
jmaskew
Sorry Mark.. this is what I have for the FICM Sync,
PID: 2209cd
long name- FICM Sync
short name-FICM Sync
min value-0.0
max value-1.0
scale factor-x1
unit type-sync
equation-{A:1}
odb header-7E0
And for the Cam/ Crank Sync i have what you posted,
Cam/Crank Sync
Min Value: 0
Max Value: 1
Scales Factor: X1
Unit Type:
Equation {A:1}
Unit header
7E0
I am looking for the PID or ODBII Mode for the Cam/Crank sync (its 2209cd for the FICM).. maybe it's supposed to be blank?
Thanks again Mark!
Old Oct 23, 2015 | 07:44 PM
bismic's Avatar
bismic
For a custom PID, you don't need a PID number.
From what I understand, the FICM sync is A:0 in the equation. The Cam/Crank sync is A:1
EDIT -
information corrected below.
Old Oct 23, 2015 | 07:48 PM
jmaskew's Avatar
jmaskew
ahh.. ok!! Thanks Mark! I'll probably try again in the morning.. I'll post the results.
Old Oct 23, 2015 | 08:20 PM
bismic's Avatar
bismic
Looking up PID 2209cd, it looks like that really is the cam/crank sync, so you need to enter the FICM sync PID. I will verify this tonight!
https://www.ford-trucks.com/forums/1...ew-gauges.html
https://www.ford-trucks.com/forums/1...t-no-clue.html
I will check on your readings tomorrow.
Old Oct 23, 2015 | 08:45 PM
bismic's Avatar
bismic
Well, post #16 (from Double4LinkDiesel) below says that PID 2290cd is actually FICM Sync and it should be A:1.
So changing the equation to A:0 will yield Cam/Crank Sync.
I think that is official because Double4LinkDiesel sounds like he is a "developer" for the TorquePro.
Sorry for the confusion - there are way too many erroneous posts on this topic!!!
Old Oct 23, 2015 | 09:17 PM
jmaskew's Avatar
jmaskew
hahaha.. yes.. just updated the equations!!! I really like the Torque Pro app, I've been using it for over 3 years now. I am reading many posts about cold no start issues and it seems everyone has at least one fault code. I have none... very weird. I just checked on my batteries and it seems the drivers side battery is taking a very long time to charge, it took over 2 hours to go from 64% to 72% on a 15amp charger. the passenger side charged from 61% to 100% in about 2 hours.
Old Oct 24, 2015 | 10:28 AM
jmaskew's Avatar
jmaskew
Ok.. this is what the results are while cranking..
IPR% 83.9
RPM 167.2
InjPW 0.0
FICM Sync 1.0
CAM/Crank Sync 1.0
FICM 47.5
I am charging the batteries again to keep them topped up.. let me know if you need any other readings.. thank you!!
Old Oct 24, 2015 | 10:34 AM
jmaskew's Avatar
jmaskew
I'm missing the HPOP and ICP volts... I'll let the batteries charge a few then report back
Old Oct 24, 2015 | 10:55 AM
jmaskew's Avatar
jmaskew
Ok.. did another crank with all parameters this time.. I hope.. haha
IPR% 83.9
RPM 172.2
InjPW 0.0
FICM Sync 1.0
CAM/Crank Sync 1.0
FICM 47.5
HPOP 246.2
ICP Volts 0.5
I'm thinking this isn't a good sign....
Old Oct 24, 2015 | 11:03 AM
bismic's Avatar
bismic
Looking like you have a high pressure oil leak or your HPOP has bit the dust. I would lean towards the HPOP.
Old Oct 24, 2015 | 11:09 AM
  #28
jmaskew's Avatar
jmaskew
What is strange is that yesterday the HPOP was reading over 900 psi while cranking... could warn batteries cause this? I haven't had them checked yet but they aren't holding charge very well I noticed today... I only got a 4, 20 second cranks before the rpm's started to go down.. now the batteries are at 70% according to my charger. They were at 100% when I started this morning.
Old Oct 24, 2015 | 11:26 AM
  #29
bismic's Avatar
bismic
I agree that 900 psig should have been enough, but that number was a mystery. The 0.8 volts correlates to less than 500 psig. I believe that the PCM would have prevented the start at 0.8 volts (thus the 0 fpw value).
Weak batteries can certainly cause a variety of issues. I will always recommend correcting a battery issue before proceeding any further with troubleshooting.
Old Oct 24, 2015 | 11:28 AM
  #30
jmaskew's Avatar
jmaskew
If the screen on the IPR sensor is broken would I still get the same readings for the IPR % ?
