Carb swap
Old Nov 4, 2015 | 11:07 AM
  #61
dixie460's Avatar
dixie460
What I would do is make up a way to read the position of the MLPS and OD switch, then sequence the solenoids accordingly without computer control.
EDIT: the overdrive switch is normally open with momentary contacts. Either replace it with a non-momentary switch or make up a way to store a binary on/off state.
Old Nov 4, 2015 | 11:13 AM
  #62
Willz74's Avatar
Willz74
The idea is to make it not electric but I did consider that idea I figured it was possible but mine has a failed solenoid and I'd prefer it be hydraulic anyway I realize it's not the easy way but the point isn't to get rid of the computer but instead the electrical components entirely
Old Nov 4, 2015 | 11:16 AM
  #63
dixie460's Avatar
dixie460
Ah. Okay. Well I doubt you could just throw a C6 valvebody in there, don't think that would end well and that's assuming you got it to physically fit and bolt in.
Not only does the valve body control shifts but it also regulates oil flow for lubrication and cooling. I'd say there are enough differences between a C6 and an E4 that a C6 VB won't work for sh** in there.
Old Nov 4, 2015 | 11:31 AM
  #64
Willz74's Avatar
Willz74
I was intending on using the aod or 700r4. The aod seems too small (too much restriction, too little pressure) and I believe the 700r4 wouldn't "communicate" properly (too much pressure here too little there) but I feel if I could use a c6 and electrically engage od that would be acceptable
Old Nov 5, 2015 | 01:39 AM
  #65
My4Fordtrucks's Avatar
My4Fordtrucks
^this. That is what I was trying to say. I wasn't sure if you could go 'backwards' to a hydraulic valve body. I was a Ford and then a Chrysler tech for 10 years and had rebuilt some Chrysler transmissions. Know the operation part of it just not interchangeability of parts.
There are built up AOD (or AOD-E) transmissions out there that could handle the power. Not sure how much over stock you want to go. Years ago a friend of mine ran C4/C5 transmissions in his 10.5 second 1/4 mile Mustang. I would never consider installing Chevy parts in a Ford so the 700R4 wouldn't be an option for me. You would need some sort of adapter to mount it to the Ford engine and transfer case if 4wd. The C6 is a 3 speed so no OD.
Old Nov 5, 2015 | 01:18 PM
  #66
dixie460's Avatar
dixie460
Using an AOD or 700R4 manual valvebody in your E4OD has about a zero percent chance of working.
You can't electrically engage OD. It's engaged hydraulically like any other auto transmission. The way the transmission directs hydraulic pressure to the overdrive servo is by using a solenoid. It's probably not even that simple. Rather, the solenoid is likely a pilot valve which directs pressure to one of the shuttle valves within the valve body, and that shuttle valve then moves to direct pressure to the overdrive servo.
Also, how would you control line pressure? The E4OD uses a variable force solenoid to do this, the AOD uses the throttle valve cable, and in the extremely unlikely event you actually get that thing to work, you would also need to install a governor on the tailshaft (like the AOD has). I have no idea what GM's junk uses so no comment there.
I ain't the guy that hears an off the wall idea and says it'll never work, trust me. But when I'm absolutely certain something won't work, to the point MY crazy butt wouldn't even try it, I'll call it out.
Old Nov 5, 2015 | 04:03 PM
  #67
Willz74's Avatar
Willz74
I guess that's it I'm getting rid of the transmission either way
I figured it was worth bringing up in case someone knew enough to figure it out
I still think it'd be cool and maybe ill do some research and figure something out one day
Old Nov 9, 2015 | 05:54 PM
  #68
Willz74's Avatar
Willz74
Driveshaft is almost ready any thoughts on balancing it
hooziewhatsit
May 11, 2014 06:56 AM
Wayne Waldrep
Jul 26, 2013 01:53 PM
stroketildeath
Jul 30, 2012 08:21 PM
Hobbybigred
Aug 8, 2009 12:58 PM
bad96
Mar 17, 2008 08:55 AM
