Carb swap
Old Oct 11, 2015 | 10:57 PM
Willz74's Avatar
Willz74
Carb swap
So I just lucked into a new 1995 extended cab f150 4x4 for free but it has no motor and a bad e4od transmission so it's getting a carb c6 and I'm getting rid of the slip yoke assuming it has one my question is will the mechanical fuel pump suck through the electric ones it had or do I need to take them off
Old Oct 11, 2015 | 11:03 PM
Shadow944795's Avatar
Shadow944795
Gonna need to remove ye old electric pumps in order for it to work correctly bud.
Old Oct 11, 2015 | 11:08 PM
Willz74's Avatar
Willz74
I was hoping to leave them on for a primer but whatever thanks anyway
Old Oct 11, 2015 | 11:40 PM
Willz74's Avatar
Willz74
The motor I got is a 351 out of a 94 how do I tell if its MAF if it is I might have some parts to sell
it seems like it's too early but it's not original to the truck I got it from and the distributor has some weird wires going to it
Old Oct 12, 2015 | 12:18 AM
88XLTLariat's Avatar
88XLTLariat
Hey Willz, this link will answer your MAF question:MAF sensor 1995 f-150 5.8 [351] windsor - Ford F150 Forum
Old Oct 12, 2015 | 12:39 AM
Willz74's Avatar
Willz74
Thank you it is MAF what all do I need for a MAF swap in my 91
Old Oct 12, 2015 | 06:15 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Is '91 a typo because you were asking about a '95 earlier. Hard to know what you need for the swap. Do you have the complete engine including the harness? You would, at least, need the '94 ECM to run the MAF. Which computer would depend on the transmission you are using.
Old Oct 12, 2015 | 10:51 AM
Willz74's Avatar
Willz74
It's a 91 with a 302 I believe the 95 was also MAF I'm just hoping you can point me to a list of sensors or something that I need
Preferably with pictures
The 94 motor has most of its wiring gone the 95 has the motor and all that whoever pulled it needed so I'm not expecting to have everything I need but maybe I'll get lucky again
Old Oct 12, 2015 | 11:01 PM
Willz74's Avatar
Willz74
Is there any particular way to identify a 351 fuel pump eccentric or are they all the same I've got a few laying around but I'll need to find them
Until then am I looking for any given one or a specific one
Old Oct 14, 2015 | 01:26 AM
Willz74's Avatar
Willz74
I got the eccentric figured out they seem to be universal
It seems the shift linkage is different
Does anybody have a picture of the 87-91 shift linkage and a link to a good e4od to c6 swap thread
Old Oct 15, 2015 | 03:47 PM
Willz74's Avatar
Willz74
So here is the c6 going into the truck my question is what do these wires go to they're on the drivers side
It's out of an 89 bronco
Old Oct 15, 2015 | 04:57 PM
rla2005's Avatar
rla2005
Neutral Safety Switch. Also contains the circuit for reverse lights.
Old Oct 15, 2015 | 05:17 PM
Willz74's Avatar
Willz74
Thank you I was starting to get lonely in here
Old Oct 15, 2015 | 05:22 PM
rla2005's Avatar
rla2005
echo..echo..echo..
Old Oct 15, 2015 | 06:23 PM
Willz74's Avatar
Willz74
Any ideas what caused that all the rest look like the left one
My guesses are it's reused or it's plugged
