Carb swap
Old Oct 18, 2015 | 04:17 PM
  #31
My4Fordtrucks's Avatar
My4Fordtrucks
The flexplate should be for the engine balance and not depend on the transmission it is attached to.
Old Oct 18, 2015 | 07:47 PM
  #32
Willz74's Avatar
Willz74
I ended up pulling it off anyway because of the mid plate. I kept the e4od flexplate because of the ring gear
Old Oct 18, 2015 | 08:07 PM
  #33
rla2005's Avatar
rla2005
Originally Posted by BruteFord
Now that you mention it, the pre/post 92 thing might be right. In that case however I'd simply use a fuel pressure regulator. Or replace the HP in tank pumps with the pre 92 LP ones. All fuel pumps are better at pushing fuel then pulling it, including mechanical pumps.
1990 was the first year for the in-tank high pressure pump.
  #34
rla2005's Avatar
rla2005
Flex plate is engine and transmission dependent.
Old Oct 18, 2015 | 08:15 PM
  #35
Willz74's Avatar
Willz74
The important thing is will it work they're both off 351s one is just c6 the other is e4od
And I know they switched to two pumps by 1991 because mine is two
Old Oct 18, 2015 | 09:03 PM
  #36
rla2005's Avatar
rla2005
Just pointing out there are more than one factor to consider.
Old Oct 18, 2015 | 09:26 PM
  #37
Willz74's Avatar
Willz74
Any ideas where to get a new fixed yoke output shaft for a bw1356
Old Oct 19, 2015 | 11:36 PM
  #38
Willz74's Avatar
Willz74
The fun begins tomorrow but I still have a few questions I'm still looking for a new output shaft for the bw1356
And has anybody heard of a shelf and console where the visors go is it stock or did someone put it in there it's not a good picture but
Old Oct 20, 2015 | 08:37 PM
  #39
Willz74's Avatar
Willz74
How difficult is it to swap e4od gears into a c6 and does anyone know where to find some instructions on doing it
Old Oct 21, 2015 | 02:08 PM
  #40
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
https://www.ford-trucks.com/forums/1...o-rebuild.html
Not for the faint of heart!
Old Oct 21, 2015 | 08:41 PM
  #41
Willz74's Avatar
Willz74
Considering I broke off a bolt then broke the easy out then broke a drill bit then broke a tap I think I shouldn't be pulling apart a transmission especially since I've never done so much as check the oil on an automatic
Probably should get my tools confiscated
Old Oct 21, 2015 | 09:13 PM
  #42
NotEnoughTrucks2014
We've all been there!
Keep at it, nothing is impossible, ask all the questions you can, no such thing as a stupid question, only stupid answers.
E4OD can be a B#$%&H to work on, but the C6 is not too bad. Get a manual and keep everything spotlessly clean.
Old Oct 21, 2015 | 09:29 PM
  #43
Willz74's Avatar
Willz74
I'm getting rid of the slip yoke so I'll call it good after changing that
I'm planning on welding the output off the transfer case to the drive shaft any thoughts or better ideas
Old Oct 23, 2015 | 03:41 PM
  #44
Willz74's Avatar
Willz74
So I flipped the linkage over but the throttle kick appears to be messed up it has about 60* of freedom is that right
And which way is it supposed to go to work
Old Oct 23, 2015 | 09:13 PM
  #45
Willz74's Avatar
Willz74
Unrelated question here but what years can you flash the check engine light for codes and what years are obd1 and which are obd2
