swithing to carb
Old Mar 17, 2008 | 05:52 AM
bad96's Avatar
bad96
swithing to carb
I am look at getting a 97' 250 4x4 with a 351 in it, but the motor needs rebuilt. I have an intake and carb for a 351 and was wondering if I can use them instead of the fuel injection and what issues will I have with the computer. Can I use a different computer to keep my stock gauges. The truck is also a 5 speed.
Old Mar 17, 2008 | 08:41 AM
Conanski's Avatar
Conanski
It's WAY more trouble than you think, you can swap the longblock in a weekend if you buy a reman or donor motor, switching to carb will take a lot longer, cost thousands more and won't run as good.
Old Mar 17, 2008 | 08:43 AM
jroehl's Avatar
jroehl
What Paul said. Those who have problems with the Ford EFI system and think carbs are better for the most part haven't learned how to diagnose and fix the EFI. It's far more reliable...
Jason
Old Mar 17, 2008 | 08:55 AM
Conanski's Avatar
Conanski
Yeah.. besides the carb and intake, you need a stand alone igniton and distributor, a low pressure fuel pump to replace the high pressure intank pump, and you will have to completely rewire the motor and dash to work with these parts.
