0_________0 I really don't wanna know what was back there if its wired into the truck. Because I have no idea what a phone line, a coaxial cable and some random computer connector would of went to.
That is wiring for a 90's style in car cellphone. Motorola by the looks of it. The round connector is for the antenna. Likely goes to a window for a glass mount antenna or a bushing through the roof, or on a fender for a conventional mount. The cable with the multi pin connector will go to your fusebox. The telephone style cable is an extension for the handset. All can be removed. I put hundreds of those in back in the day.
Gonna need to remove ye old electric pumps in order for it to work correctly bud.
I'm 99% sure this isn't correct. That truck will have up to 3 fuel pumps in total. A low pressure fuel pump in each tank and a high pressure pump on the frame rail. To fuel a carb all that needs to be done is to remove the high pressure fuel pump on the rail and use the in tank pumps to push the fuel to the carb WITHOUT a mechanical pump at all. This is how both my 86 and 87 are set up setup stock.
I'm 99% sure this isn't correct. That truck will have up to 3 fuel pumps in total. A low pressure fuel pump in each tank and a high pressure pump on the frame rail. To fuel a carb all that needs to be done is to remove the high pressure fuel pump on the rail and use the in tank pumps to push the fuel to the carb WITHOUT a mechanical pump at all. This is how my 87 is setup.
Might have to go with the 1% here, but the three pump setup is pre '92 or even earlier if I'm correct. The OP has a '95 truck which should use the fuel delivery modules with the HP pumps in the tank.
I think removing the pumps is the best idea. Had a friend try this with a GM product and it starved for fuel trying to suck through the in tank pump. Worked great when he removed the pump. Short piece of hose worked well.
Now that you mention it, the pre/post 92 thing might be right. In that case however I'd simply use a fuel pressure regulator. Or replace the HP in tank pumps with the pre 92 LP ones. All fuel pumps are better at pushing fuel then pulling it, including mechanical pumps.
The new engine was attached to an e4od so it has an e4od flexplate do I need a c6 flexplate or will it work I have both for a 351 but would prefer not to have to pull them off
