Easiest way to replace #7 glow plug
Old Oct 6, 2015 | 04:18 PM
bobv60's Avatar
bobv60
What is the easiest way to replace #7 glow plug? remove inner fender or from the top?
Old Oct 6, 2015 | 06:28 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I prefer to see what I am doing so I remove the inner fender. That being said I would also recommend replacing them all on the side as well as the harness. They are easy to break even with the tool.
Old Oct 7, 2015 | 04:45 AM
Yahiko's Avatar
Yahiko
Some C-4 does the trick.
You can do it from the top side. It's easier to remove the valve cover for a bit
more work room. Or if you want a lot of room pull the evaporator core cover.
Just a few screws some, clips and Starlock® washers. The Starlock® are on the
heat shield.
Sean
6.0L Tech Folder
catapeed
Apr 14, 2016 08:27 AM
Restlesswildman
Mar 25, 2016 03:19 PM
Bran Hollywood
Feb 5, 2016 08:25 AM
chaser1602
Jan 3, 2016 10:01 AM
CORNBOY
Sep 4, 2009 04:52 PM
