2007 250 6.0 #5 glow plug code
Old Feb 4, 2016 | 06:31 AM
Bran Hollywood's Avatar
Bran Hollywood
After starting my truck, I can hear sounds a little off. I do run a chip, a edge with juice. Only have the chip to monitor my engine & it works great. It shows me the code that the number five glow plug has Circuit malfunctioned. After a few minutes and restarting the vehicle it goes away, is this a problem for the future or should I have it looked at now?
Old Feb 4, 2016 | 01:25 PM
davester250's Avatar
davester250
easier to fix when it's only one problem. when it becomes "a bunch of codes are set and the engine doesn't run", it becomes much harder get it back in running shape.
like the graffiti/broken window policy some cities have.
Old Feb 5, 2016 | 03:17 AM
Yahiko's Avatar
Yahiko
FTE Remembers
Tends to be one of three things.
Bad glow plug
Bad glow plug harness
Bad glow plug module.
Here is something about the Glow Plugs I posted some time ago and
I think you will find it helpful.
https://www.ford-trucks.com/forums/1...ce-manual.html
Also you may want to come on over to the 6.0L Forum. >>> 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Sean
6.0L Tech Folder
Old Feb 5, 2016 | 04:11 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moved to 6.0L PSD forum..
Old Feb 5, 2016 | 08:25 AM
bobv60's Avatar
bobv60
I had a #7 code. It was a bad glowplug. I removed the right front inner fender to access mine. The harness broke trying to remove it from the plug but I had a new one ready. I found Motorcraft glowplugs at Orileys for under $ 10 each so I replaced all 4 on the right bank.
Blakshukvw
Dec 17, 2016 03:37 PM
lostru
Jul 8, 2015 10:24 AM
cope1972
Nov 21, 2014 09:17 PM
HowieE
Nov 23, 2009 07:28 PM
popkorn
Sep 14, 2003 07:31 PM
