Replacement plug ends?
Old Mar 23, 2016 | 09:19 PM
Restlesswildman's Avatar
Restlesswildman
Awhile ago I had a new Camshaft Position sensor put in.
While pulling the wiring harness on the beast tonight to replace the HPOP, I noticed that the plug was busted. Can a replacement one be bought?
Old Mar 24, 2016 | 02:36 AM
Yahiko's Avatar
Yahiko
I have a link to the pigtail catalog.
http://www.fordparts.com/fileuploads...icationkit.pdf
or you can just use the set I posted below.
Here are some places to buy parts. I have used Sumit but not the others.
Socket Assemblies & Harness Connectors
FORD Wiring Connectors and Pigtails - Free Shipping on Orders Over $99 at Summit Racing
Automotive Electrical Connector Pigtails, Terminals, Tools and More
Sean <BR>
6.0L Tech Folder
Old Mar 24, 2016 | 08:18 AM
npccpartsman's Avatar
npccpartsman
I'd be surprised if the cam or crank sensor plugs were available since they are in a shielded part of the harness and it's recommended NOT to replace or repair them. I know someone makes them but they may not be available to the public. You might try Alliant also.
Old Mar 24, 2016 | 04:35 PM
Yahiko's Avatar
Yahiko
The repair is very easy if you have the correct parts and a few special tools.
Just the DMC HX4 crimp tool is all the special tools you really need.
Sean <BR>
6.0L Tech Folder
Old Mar 25, 2016 | 08:22 AM
Restlesswildman
If I can get just the plug, I should be able to release the pins from the plug and change out the plug only. No reason to cut wires!
Old Mar 25, 2016 | 03:19 PM
Yahiko's Avatar
Yahiko
I don't recall the name but DieselTechRon has someone he was talking
about for all sorts of plugs and pigtails. If you can find that name they
might have something. Or if not you could try a used harness and pull
that fitting from it.
Sean <BR>
6.0L Tech Folder
Yahiko
Arizona Chapter
Oct 17, 2016 12:46 AM
Yahiko
Sep 19, 2016 05:16 PM
Yahiko
Jul 23, 2015 07:07 PM
Yahiko
Jul 10, 2015 12:12 PM
