New guy questions
Old Aug 20, 2015 | 01:25 AM
vanthony's Avatar
vanthony
New guy questions
Sorry to sound so elementary to some, but what is "bullet Proofed" and EGR deletes? I am trying to buy my first 6.0 (2003) and keep seeing these terms pop up and obviously need to know what they mean.
Thanks,
Vic
Old Aug 20, 2015 | 01:41 AM
lupuseven's Avatar
lupuseven
EGR Delete is a general term used when bypassing the EGR cooler
there are several ways to do it. if you live in a Smog Cert state like me one would weld freeze plugs to the ends of the EGR cooler and reinstall. there are good kits to do it safer if you live in a "leave me alone state" IPR is the best.
Bulletproofing is a term used for doing the fixes for the known major issues with the 6.0l, EGR delete is one of them. head studs, coolant filters, external oil coolers, ect are some more.
does yours need to be bulletproofed.. absolutely not. there are plenty out ther that are bone stock and doing great.
most of the bulletproofing is for the series of events that are created once an oil cooler gets clogged. clogged oil cooler -> EGR cooler bursting -> blown head gaskets or worse. this can also be prevented by monitoring engine health with a live OBDII reader.
Known probs and the bullet proofs
oil cooler clogs - coolant filter helps catch particle before the oil cooler. Extreme - external oil cooler.
EGR cooler bursting- EGR delete or BPD EGR cooler
blown head gaskets (also caused by too much boost) - Head studs (ARP are popular)
there are other know issues too which dont need to be addressed until it comes time to replace them, which may be never.
Old Aug 20, 2015 | 02:27 AM
Yahiko's Avatar
Yahiko
Being an 03 he already has the better cooler in his. The round one.
So there is no need to replace that with one of the upgraded ones like
we do when we have the square coolers.
Sean
6.0L Tech Folder
Old Aug 20, 2015 | 07:23 AM
white Buffalo's Avatar
white Buffalo
Thanks,
Vic
I was in the same situation about 2 weeks ago. It was suggested to me to get an OBD-II scanner and monitor engine coolant temps, engine oil temps & FICM voltages while test driving. If the difference between the temp sensors is greater than 10-15 degrees than you could be replacing the oil cooler and/or EGR in the short term.
Also, take some pics of the degas bottle and the surrounding engine area and post the pics up. These folks on this forum can help you determine if she has or is puking coolant.
My knowledge of the 6.0L is pretty limited, but this is what I have learned so far and the advice helped me buy my first 6.0L.
Old Aug 20, 2015 | 07:36 AM
white Buffalo
This is a great thread in the Tech Folder for those considering buying a 6.0L.
https://www.ford-trucks.com/forums/9...used-6-0l.html
Old Aug 20, 2015 | 08:03 AM
evan1242's Avatar
evan1242
just some food for thought here, but i have an 03 and when i first got it my deltas were great but my round EGR cooler still ruptured.
luckily i noticed some smoke out of my passenger mirror and immediately shut it down.
Grant-Dieseltech
Nov 22, 2014 12:05 PM
Jimbo532
Jul 9, 2013 10:37 PM
Poorboy04
Jun 14, 2013 03:32 PM
MC5C
Mar 23, 2013 12:34 PM
exy
Aug 11, 2011 05:50 PM
