Egr leaking and pluged oil cooler
I have a 2003 6.0 and the egr cooler started leaking and my deltas are at 13 degrees I am currently running ford gold coolant and a coolant filter that I put on 5,000 miles ago when I did a flush with distilled water (no chemicals) now I am going to do a egr delete and oil cooler replacement and want to change to elc coolant I was wondering how I should flush the coolant system since my egr cooler is leaking and I don't want to replace the oil cooler again in 5000 miles. Also where is the best place to get the oem oil cooler
You SHOULD spend as much ttime Flushing as Getting the Oil Cooler Out
Guess what I mean is Lots Of FLUSHING VC-9 and Pull Thermostat
Add A Coolant Filter
Best Place to get a Oil Cooler Used to be Tousley Ford
That's Not enough spread that we see 03 EGR Coolers Die Normally
Very Common to see 03 Round egr Cooler still Holding at 25-35* Plus Spread
They should have gave everyone Round EGR Coolers They would have saved themselves lots of greif
Do all YOUR TEMP SENSORS Read the same temp after cold soak????
Not trying to hijack but I just found out that I am going to have to do the same repairs. I am opting for the oil cooler replacement and an egr cooler bypass rather than the egr delete as I am trying to keep things as stock as possible.
I found a cooler delete kit but am looking for feedback as to what to look for in a quality replacement. Performance Machine & MFG. 6.0L Powerstroke EGR Cooler Delete Kit
As for the oil cooler is there an upgrade or better brand/model over stock or is the stock oil cooler good enough?
Hopefully this can add some more options and input to both of our repairs.
YOUR EGR Cooler Will be GONE With THIS^^^^^^^^^^^KIT!!!
Wont Look Stock if that's what your After
I do Like that Kit since you don't have to change the Uppipe Just Cap it
05+ Had the Scoop in OEM Uppiep that's why some guys Opt to Get OEM Upipie out
Normaly when they Leak its NOT Recommended to Flush then BUT
If at ALL Possible I would Flush Before OIL COOLER Change Grab a Lawn Chair and sit where you see the Tailpipe
How Bad does it Leak???
The Proper Flush will require 1 Hour High IDLE (1100rpm) In Driveway thermostat OUT VC-9 Cleaners!!
If it Only Leaks alittle Do the Flush and Watch the Exhaust Pipe the entire Time Shut it Down if Lots more White Smoke starts coming out
olfordsnstone
12-31-2017 08:46 PM
imcqueen
11-16-2017 04:50 PM
