Transmission cooler layout/operation?
Old Aug 19, 2015 | 08:47 PM
mattdoc88's Avatar
mattdoc88
Can anyone explain the transmission cooler layout in our trucks? Is it oil to air, or is it oil to water, using the engine coolant to cool down the transmission fluid? I searched and all I can find is threads about people using 6.0 coolers on 7.3s. No real info about the 6.0 transmission cooler in a 6.0 truck.
Old Aug 19, 2015 | 09:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is both an air to oil as water to oil cooler. First it goes through the cooler in the radiator where engine coolant lowers the temp, the to an air to oil where it is cooled again.
Old Aug 19, 2015 | 09:22 PM
mattdoc88's Avatar
mattdoc88
Thanks, mark.
I was confused because I thought it was oil to water due to where the connections are, but my Trans Temps stay 20F under the coolant temp when cruising on the highway towing 6000lb, which made me think oil to air.
Plus the 7.3 guys using these coolers meant it almost had to be oil to air.
So is the risk of mixing coolant and Trans fluid worth the cooling an oil to water cooler provides?
Old Aug 20, 2015 | 01:15 AM
lupuseven's Avatar
lupuseven
I have had many vehicles over the years with tranny oil to water cool never had an issue.
Old Aug 20, 2015 | 06:14 AM
mattdoc88's Avatar
mattdoc88
Same here, but that's not exactly answering my question. Since coolant will destroy the guts of our very expensive transmission, why not go oil to air only?
It just seems odd that my trans Temps stay under the ECT when towing, if it's oil to water. Does it go thru the rad cooler and then thru the air cooler?
Maybe it was just a frontal area limitation for the cooling system group. I've heard they always seem to be fighting the designers who are responsible for aesthetics and aerodynamics.
Old Aug 20, 2015 | 07:08 AM
Mark Kovalsky
The risk is very small, and the amount of cooling that the water to oil cooler does is very large.
The fluid goes to the radiator cooler first, then to the air to oil cooler.
The ATF never sees coolant at engine temperature. The cooler is on the cold side of the radiator. This side of the radiator can be as much as 100F colder than engine temperature. The coolant goes through the radiator to be cooled, right? The ATF is in the side that's already been cooled.
The radiator cooler is especially important when there is little airflow. This happens when backing a load. If you don't have a radiator cooler, the air to oil cooler is be unable to keep the trans cool in this condition.
Old Aug 20, 2015 | 07:22 AM
mattdoc88's Avatar
mattdoc88
Wow, 100f. That would make all of this make sense. I just didnt think it would be that much. Your explanation about low airflow situations makes perfect sense. I'm used to construction equipment without a fan clutch... so 100% fan speed relative to engine rpm all the time.
I am involved in dyno testing of Cummins QSB 6.7 engine installations at work, and when we do a cooling system test, the bottom radiator tube is usually within 10 or 20f of the top tube. These are full power runs, ran until Temps stabilize. The log I'm looking at now was 32 minutes long at 100% load. The greatest difference between top and bottom tube temp was 19.9F. And we only use oil to air transmission coolers. I've noticed competitors machines that have oil to water coolers though, and they are much smaller than our oil to airs.
Old Aug 20, 2015 | 08:48 AM
Mark Kovalsky
You'll see 15-20 degrees difference across the radiator on a stabilized full power run. It didn't sound like that's what you were talking about in your truck.
Old Aug 20, 2015 | 09:03 AM
mattdoc88's Avatar
mattdoc88
Right, I was talking about highway driving with a trailer, and I guess it was unfair to compare that to a full power dyno run. I don't have any experience with partial load cooling tests.
cabloom300
Jun 14, 2023 01:15 PM
zems
Jan 7, 2014 06:25 PM
Rocky RaetzIDI
Dec 22, 2013 10:52 PM
john11139
May 14, 2011 07:42 AM
ilo9
Nov 15, 2010 04:15 PM
