Sponsored by: Real Truck
Torque converter issue
Old Aug 10, 2015 | 02:18 PM
Black_6.0's Avatar
Black_6.0
I have an issue to where every once in a while my truck will not shift and when it does shift it slams into gear, and my overdrive light flashes and then I'll turn the truck off let it sit and crank it back up and it drives fine and the overdrive light is off. It shifts normal and smooth other than when this happens. Not sure if it is my torque converter or maybe a solenoid or what. Any help.? My truck is an 07 f250 6.0 with 192,000.
Old Aug 10, 2015 | 02:58 PM
evan1242's Avatar
evan1242
do you mean the tow/haul light flashes?
if so that means a code or codes were stored.
an auto parts scanner will not read these codes.
Old Aug 10, 2015 | 04:54 PM
Black_6.0's Avatar
Black_6.0
Yes my tow/haul light sorry. But yes, and it only did it twice it hasn't messed up on me again yet and the light has not flashed again. Any ideas.?
Old Aug 10, 2015 | 05:00 PM
evan1242's Avatar
evan1242
have the codes checked by someone that knows what there doing.
if it flashed a code should be stored.
if the truck is now running correctly, you will most likely still have a code.
Old Aug 10, 2015 | 05:11 PM
Black_6.0's Avatar
Black_6.0
Hmm, I didn't know the code would be stored even if the light wasn't on. I'll have to take it and get it checked then. I appreciate the help.
Old Aug 10, 2015 | 05:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The code will stay in memory for about a month after the last time the light flashed.
Rick Stacy
Mar 11, 2017 10:17 AM
KING-RANCH02
1997 - 2003 F150
Dec 9, 2015 08:43 PM
BRay09
Jun 8, 2010 06:12 AM
SALVY
Mar 19, 2009 09:31 AM
iverger
1983 - 2012 Ranger & B-Series
Feb 18, 2004 04:14 PM
